Old 07-24-2006   #1
oil filter relocation
I am relocating my oil filter for easier access (downpipe doesn't allow me to take the filter off) but i want to know if it's safe to place the filter up in the driver's fender, like in the area infront of the washer fluid neck, were the ps fluid container used to go? I just wanna make sure it's not only able to work at a level even with the current location, since the oil system is somewhat pressurized. I want to make sure oil will flow to and from the filter if it's in a higher location. Thanks.
-A. Swift
Old 07-24-2006   #2
Re: oil filter relocation
get the forward facing filter housing off the mighty max pickup
Old 07-24-2006   #3
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
yep. I just bought one from someone on the dsmlink forums.
7/25/09
Old 07-24-2006   #4
they are dirt cheap brand new from mitsu too, like 25 bucks!
Old 07-25-2006   #5
I was going to get the forward facing filter like shep runs (i've got the link somewhere) but, it then get's rid of my oil cooler, and returns it to the older cooler, which shane (ecoli) knows from years back, can blow apart, and send your white car into a ditch on your way to the MG KK meet..
-A. Swift
Old 07-25-2006   #6
I just need to know if it's ok to mount the filter up higher then it's current location. That's all. I wanna make damn sure it's ok for this car, because some cars' oil system isn't as pressurized, and their filters need to be mounted level, or an in-line oil pump is used.
-A. Swift
Old 07-25-2006   #7
I figured it out. I just need to figure out what -an size to go with. -10?
-A. Swift
Old 07-26-2006   #8
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
Is there a front facing one with the external oil cooler spots?
7/25/09
Old 07-26-2006   #9
nope, not from the factory anyway. there are a bunch of guys in florida that run those housings and their oil temps never get dangerous. honestly unless you are roadracing the thing, who needs an oil cooler?
