Old 08-26-2006   #1
Nitrogen?
Where could a person like myself find nitrogen to fill up my tires, instead of air? I do not wish to purchase a bottle of it to store in my garage, but just to fill the tires with. It lasts longer, doesn't leak out, due to larger molecules, and stores better. Just curious.
-A. Swift
Old 08-26-2006   #2
Re: Nitrogen?
Go to a place that rebuilds snowmobile shocks.
Old 08-26-2006   #3
9guy9
Dumb and...........
Re: Nitrogen?
Know some one that work on airplanes. They use it in their shocks also.
My car will be faster tomorrow.
9guy9 is offline   Reply With Quote
Old 08-26-2006   #4
Re: Nitrogen?
damn! sweet! Does anyone else try this mod?
-A. Swift
Old 08-26-2006   #5
Re: Nitrogen?
I don't know why you want to bother. The reason it's used in racecars is because of its inert properties, it will not expand/contract as much as normal air when heated/cooled.
Old 08-26-2006   #6
Re: Nitrogen?
Look for a welding/gas supply company.
Old 08-26-2006   #7
Re: Nitrogen?
Besides that, good luck finding someone that has it with an air chuck on it.
Old 08-26-2006   #8
Re: Nitrogen?
All the info you need.
Old 08-26-2006   #9
Re: Nitrogen?
I was wondering this more-so for like hossier qtp, just set it at 13 psi or so. But, I'm a way's off for it. I was actually wondering if it expands under heat like usual. Thanks guys.
-A. Swift
Old 08-26-2006   #10
Re: Nitrogen?
Tires plus in blaine uses it. My buddy works there and they just got it in a couple of months ago.
Old 08-26-2006   #11
9guy9
Dumb and...........
Re: Nitrogen?
-A. Swift
nitrogen is a very stable gas and dosn't change much under different temps. That is why it is used in shocks. I have read that some tire places are starting to offer it, although I havn't heard of any in particulre.
turbotralon1g; any idea how much it cost to have your tires filled with it at TP?
Old 08-26-2006   #12
tim
tim's Avatar
Re: Nitrogen?
A guy came into work today and was talking about filling his tires with nitrogen. He said it was something like $4 per tire to do it. That seems awful steep to me? I am not sure where it was either, didnt bother to ask.
Old 08-26-2006   #13
Black97civic
35mpg
Re: Nitrogen?
I am pretty sure costco does it, or at least they used to. Dunno if you gotta pay extra if you didn't buy tires from them or not, I just remember seeing a sign about it there a year or so ago, might be worth a phone call.
Old 08-27-2006   #14
dumb_ricer
Hates Everything
Drives: Neon
Re: Nitrogen?
I think the sams club uses nitrogen to fill all there tires. Thats what I heard from heresay at least.
And nitrogen really isn't needed in a street car. Like others have said, it is mainly for road racing, as tire pressures before running and after lapping can differ like 15psi aka a shitton.
Nitrogen is still going to leak out of almost any hole/bead leak in a tire, it will just take slightly longer. If you have a leak, just have it repaired or repair it yourself. If you use bead sealer on both beads and bead seal the valvestem, the odds are tire pressure will stay about the same.
Oh, and make sure to fill up with winter air, it lasts longer than summer air.
420A > LS1 > All Else
I > All else
Old 08-27-2006   #15
Re: Nitrogen?
Anyway, what makes you think pure nitrogen is going to leak out of tires any slower than regular air? Our atmosphere is 78% nitrogen.
Old 08-27-2006   #16
98gstaherns
I need boost in my life
98gstaherns's Avatar
Drives: '14 chevy 1500
Re: Nitrogen?
My tires are filled with it.. I did it at tires plus it was in cottage grove they may all do it though...
Tyler Aherns
-USN-
Old 08-27-2006   #17
Hoffer00
Re: Nitrogen?
If it is better and safer I would do it, but I also have $900 (total not each) rubber on all fours. Not including rims.
Old 08-27-2006   #18
Re: Nitrogen?
Safer, not any more or less safe than regular air. Better, only if you're on a track and a couple PSI difference can throw off your setup.
Old 08-28-2006   #19
dumb_ricer
Hates Everything
Drives: Neon
Re: Nitrogen?
Exactly.
The only place nitrogen has an avantage in tires, is on a racetrack. (Not drag strip)
Although I am sure that a few companies are pretty happy to be selling nitrogen filling machines like a motherfucker.
I > All else
Old 08-28-2006   #20
Jacek
Captain J-Sack
Re: Nitrogen?
And in the air, don't bother..
