Old 09-04-2006   #1
gstjoker
gstjoker's Avatar
SMIC Cleaning
I drive a 2g GST and I still have the stock smic. I've been reading up on vfaq on how to do this cleaning thing on the smic and I'm just wondering if any of you guys have done it, was there a better performance outcome or if it's even really worth it to clean up the smic. It'll be awhile until I can upgrade to a bigger aftermarket intercooler so I want to make the best of what I have right now.
Old 09-04-2006   #2
Re: SMIC Cleaning
I usually clean mine with paint thinner or lacquer thinner. It was nice knowing that there wasn't going into the intake of my car anymore. If you got nothing better to do and like your car, i say do it. But i don't know if its a performance enhancer.
Old 09-04-2006   #3
Re: SMIC Cleaning
I wouldn't call in a performance enhancer, but a performance restorer.
Old 09-04-2006   #4
Re: SMIC Cleaning
Back on one of the previous versions of these forums there was a good thread about intercooler cleaning. If I remember correctly, the general consensus among people was to use gasoline. Whatever you do, do not use muriatic acid as it will eat your intercooler.
Old 09-04-2006   #5
Re: SMIC Cleaning
Gasoline works really well. Pour some in, shake it all around and tip it a few times to make sure it runs through everything, pour out; repeat until gasoline comes out clean.
Old 09-04-2006   #6
gstjoker
gstjoker's Avatar
Re: SMIC Cleaning
Well, I'm in the process of getting some gasoline right now. I just got the damn smic out. Don't know why but maybe it's just me because it took me awhile to get it out. It doesn't look very dirty.
Old 09-04-2006   #7
gstjoker
gstjoker's Avatar
Re: SMIC Cleaning
Here's some pictures that I took after I got it out if anyone cares.
Sorry if it's too big. I don't really know how to make it smaller.
Old 09-04-2006   #8
Re: SMIC Cleaning
I cleaned out an intercooler off of an npr truck once and a lot of junk came out. I used water becuase it was free, but using a cleaning agent will be good. Have fun!
Old 09-05-2006   #9
tim
tim's Avatar
Re: SMIC Cleaning
Looks good.
For future refernce there is a free program on the internet to edit pics. It is called paint.net It is free and can do a lot of the things that the expensive programs can do. Google it, it works well.
Old 09-05-2006   #10
Elementality158
Elementality158's Avatar
Send a message via AIM to Elementality158
Re: SMIC Cleaning
Yes. Gas will work nice. A solvent will work also.
Elementality158 is offline   Reply With Quote
Old 09-05-2006   #11
gstjoker
gstjoker's Avatar
Re: SMIC Cleaning
Well, I got the smic cleaning thing done this morning. For some reason it helped solve my boost leak problem maybe because some stuff were loose I guess? Maybe it's just all in my mind but my car seems to be running a little bit better now after cleaning out the smic, but as 1viciousgsx had said, it was probably just a performance restorer.
Old 09-05-2006   #12
Elementality158
Re: SMIC Cleaning
You should check for boost leaks.
Old 09-05-2006   #13
MaseWindu
Send a message via AIM to MaseWindu
Re: SMIC Cleaning
I've used gas to clean mine, it works great. I also noticed a small pinhole around one of the pipes on mine. I covered it with the intercooler pipe and clamp and didn't have a problem. If you had a boost leak and now its gone, I would check inlet and outlet pipe just to make sure.
MaseWindu is offline   Reply With Quote
Old 09-05-2006   #14
Gravy
Who's this guy?
Re: SMIC Cleaning
I ran about 3 cups of gas through a SMIC today today to try and clean it and the last one finally came out clean-ish. Works well, gets any oil out of the intake. Thinking about cleaning out the FMIC on the car now, even if it's not a problem.
Old 09-05-2006   #15
Elementality158
Re: SMIC Cleaning
I had a bunch of holes all over in the top pipe of my IC. Just slid the hose down and it fixed it.
