Old 02-04-2004   #1
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
Does it matter if they came from an AWD or FWD? Or will they be compatible with both?
Old 02-04-2004   #2
LightningGSX
Hellbound
The AWD has a resistor soldered in position R130 on the board, to tell the cpu it is AWD, other than that they are identical.They are mutually compatible other than a difference in top speed limiters I believe.
-Nulli Secundus-
Old 02-04-2004   #3
I believe the fuel maps might be slightly different as well since the gearing is different. Steve Hill is running a FWD ECU in his AWD without any problems...then again
Old 02-04-2004   #4
SuperSleeper
Alrighty, thanks guys.
Old 02-04-2004   #5
LightningGSX
Hellbound
I've personally examined the code from AWD and FWDs and, at least in the eprom ecu's, the maps are identical.
-Nulli Secundus-
