Old 01-30-2007   #1
Elementality158
Elementality158's Avatar
Send a message via AIM to Elementality158
DSM Parts I Need OUT!
92+ Headlights -$50
92+ Corner Lamps -$20
Blow Off Valve 1g-$25
AFPR -$50
O2 Housing 1g -$30
91 Trottle Body -$30
92+ Trottle Body -$30
1g Head -$70
Intake Manifold -$40
Laser Bumper -$20
Clutch cylinders
Master and slave -$30
Prices are negotiable. These parts need to leave my parents house asap.
efcskatertravis@gmail.com or 763-300-6171
Elementality158 is offline   Reply With Quote
Old 01-30-2007   #2
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: DSM Parts I Need OUT!
What FPR and what fittings does it come with?
Old 01-30-2007   #3
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Whats the diff between the 91 and 92 throttle body?
pics or gtfo
Old 01-30-2007   #4
I want the corner lamps.
Old 01-30-2007   #5
Originally Posted by Elementality158 View Post
Laser Bumper -$20
Color? Year?
Old 01-30-2007   #6
This is a turbo car? I'll take the head if it's a turbo car. Any broken exhaust studs?
Old 02-01-2007   #7
Elementality158
92 Teal Laser. Head is in great shape just needs rebuild. valves are out. the difference with the 91 and 92 TB is the vaccume hoses. I think there is 2 that comes out on the driver side. and the 92+ has 4 coming through the passenger side. The FPR is complete. goes right on the fuel rail. plug your return line right into it. Take old one off. snap new one on, needs nothing more.
Old 02-01-2007   #8
x-pride
x-pride's Avatar
Sounds like you have a 90 throttle body and a 91-94 throttle body. The one that has four coming our of the passenger side is the 91-94. While the other one is 90.
Old 02-01-2007   #9
HiImBrian
HiImBrian's Avatar
You dont happen to know which one I need do you? 98 gsx
pics or gtfo
Old 02-01-2007   #10
x-pride
x-pride's Avatar
1G Throttle Body
  • Must be from a June '90 thru 94 car ('91-94 model year). The correct one has 4 vacuum connections on the top of the TB facing towards the passenger side of the car. The earlier '89-May'90 TB has two fittings on the top and two on the front side, this one will not work. You will re-use your 2G Throttle Position
    Sensor (TPS). The 1G TPS has only three wires while the 2G has four. The Idle Speed Controller
    is the same between the cars.
Hope this helps.
Old 02-01-2007   #11
HiImBrian
HiImBrian's Avatar
Ok I'll have to take a look when I get home this weekend and see which one I need to fit on my 2g.
pics or gtfo
Old 02-01-2007   #12
xveganxcowboyx
Wanker
Drives: 95 M3
PM sent about FPR.
I'm pretty sure the TB is just a slight difference in vaccum positioning. I don't think it makes much of a difference. Don't know for sure though...
