Old 03-20-2007   #1
blageo23
AWD4G64
blageo23's Avatar
Difference between 2.4Ls
What is the difference between the 4g64 and the g4cs(6Bolts only)? I get that one is mitsu and the other is hyundai. If I wanted to build on up what one would be better. OR are they both the same?
Old 03-20-2007   #2
tim
tim's Avatar
Re: Difference between 2.4Ls
From what I gather you need to tap the hole for the knock sensor on the G4Cs? Correct me if I am wrong though.
Old 03-21-2007   #3
I believe that OEM 4G64 parts have to be ordered through Mitsubishi and OEM G4CS parts have to be ordered through Hyundai. I have it saved on my home computer somewhere but there are supposedly differences in some of the parts. Maybe one of the shops knows: LSE, MAP, DB?
Old 03-21-2007   #4
I have never dealt with a 6-bolt 4G64, only the 7-bolt ones. All the 6-bolt 2.4l block I have used have been the G4CS. The G4CS usually has a spot for the knock sensor. The 6-bolt G4CS and 7-bolt 4G64 are quite a bit different. The 6-bolt G4CS motors have not exactly been a trouble free setup and the main cap setup leaves a little to be desired when compared to a 6-bolt 2.0l or any 7-bolt.
Old 03-21-2007   #5
blageo23
AWD4G64
blageo23's Avatar
I read the exact oposite. I read the the 2.4 main caps are "thicker" then the 2.0 ones. Also I am going to be using a "main girdle" on this setup.
Old 03-21-2007   #6
They might be, but they aren't girdled at all like a 2.0l 6-bolt or a 2.4l 7-bolt.
Old 03-21-2007   #7
the tied caps on the left and right are 2.0 caps.
6bolt 2.4s come with "free" caps, that do not have that bridge.
the girdle on both sides in that pic is made by kiggly racing.
magnus offers something similar:
4G63 6 Bolt Main Girdle
Did you ever wonder why the 6 bolts never had a one piece main girdle like the 7 bolts? Don’t worry, this piece eliminates the common fretting problem found on the main caps and main bearing wear associated with high revving engines, and more commonly with the 100mm crank engines. The 6 bolt main girdles cleverly help secure the center main to the adjacent mains on your motor. This piece is a must with all high performance engine builds. Note, this piece must be used in conjunction with main studs, and your block must be align honed.
Old 03-21-2007   #8
blageo23
AWD4G64
blageo23's Avatar
I have that item sitting in my basement right now...
Old 03-21-2007   #9
Use some ARP mains and get a good align hone and you should be good in that area i would suspect.
Old 03-21-2007   #10
BuildADSM
G4CS = 6 bolt
4G64 = 7 bolt
G4CS = Hyundai version
4G64 = Mitsubishi version
Old 03-21-2007   #11
Originally Posted by BuildADSM View Post
G4CS = 6 bolt
4G64 = 7 bolt
that wasnt the question. did you even read the thread?
Old 03-21-2007   #12
BuildADSM
yes I did... he asked what the difference was between the two. I was saying 6 bolt vs 7 bolt. that is the MAIN difference is and I said the rest incase someone wasn't sure and incase someone was ording parts...
I currently have a G4CS block sitting in my garage BTW
Old 03-21-2007   #13
blageo23
AWD4G64
blageo23's Avatar
Actaully there is a 4g64 6bolt so that post is incorrect
How much for the block(and crank im assuming) PM me!
