Old 06-13-2007   #1
driftn1g
boost tap
i tapped mine to the fuel pressure thing mounted on the firewall (driver side) is this going to be as accurate as other tapping places??
Old 06-13-2007   #2
Re: boost tap
Yes, just make sure you tapped into the line running from the manifold to the solenoid, not the solenoid to the FPR.
Old 06-14-2007   #3
driftn1g
Re: boost tap
i replaced the one way plastic fitting thats all ready on there, with a T, then connected my boost gauge
Old 06-14-2007   #4
driftn1g
Re: boost tap
ok i figured it out
Old 06-14-2007   #5
Re: boost tap
The FPR spot isn't the most accurate; however its the most common because its easily accesible and an easy place to tap into. I think the intake manifold would be most accurate.
Old 06-14-2007   #6
driftn1g
Re: boost tap
vfaq told me the FPR is best..
Old 06-14-2007   #7
Re: boost tap
The line running to the FPR solenoid comes directly off the intake manifold, make sure you tap before the solenoid as I previously mentioned though.
Old 06-15-2007   #8
Re: boost tap
My magnus SMIM has an extra line just for the boost guage. WOOT.
