Old 07-28-2007   #1
justinhill
BetHiLow Streak Un-Censored Champion! League Bowling Champion! Snowboard Champion!
Drives: 98 gst eclipse
Send a message via AIM to justinhill
aahhhh problem
i still cant figure this problem out it hessitates at 4 thousand rpm i flushed the fuel rail and fuel injectors but nothing but the codes that where sent to the ob2 scanner are p1400 p1104 p1105 anyone know
justinhill is offline   Reply With Quote
Old 07-28-2007   #2
BLaCk_1cE
BLaCk_1cE's Avatar
Drives: TB IX SE
Re: aahhhh problem
P1400 Manifold Differential Pressure Sensor Circuit Malfunction
P1104 Turbocharger Wastegate Solenoid
P1105 Fuel Pressure Solenoid
Old 07-28-2007   #3
justinhill
Re: aahhhh problem
for p1400 where is that sensor located
Old 07-28-2007   #4
BLaCk_1cE
BLaCk_1cE's Avatar
Drives: TB IX SE
Re: aahhhh problem
Something to do with intake manifold or or your exhaust manifold
loss of pressure in intake manifold is my guess. Could be also referring to the MAP sensor (?)
I have also heard of this code to be EGR Valve Circ Electrical Malfunction
Start by cleaning out the egr tube first to remove carbon buildup, check vacuum hoses/electrical connection to the EGR solenoid/valve (assuming you have EGR)
Old 07-28-2007   #5
justinhill
Re: aahhhh problem
yeah i do have it
