Old 08-15-2007   #1
Bunta
Bunta's Avatar
Installing FMIC
What do you guys use for cutting the metal part of the front bumper? I have my fmic all in and bolted up but the metal frame on the front bumper is stopping it from bolting up to the car. I was just wondering what you guys used to get it on.
1990eagle talon tsi awd
"What you just said was the most idiotic thing i've ever heard, everyone in this room is now stupider for hearing what you just said."
Bunta is offline   Reply With Quote
Old 08-15-2007   #2
Re: Installing FMIC
Sawzall, Plasma cutter, Cutoff wheel, anything that will cut through the metal will work
Old 08-15-2007   #3
Re: Installing FMIC
Yup, sawzall is what I've always used. A hack saw or any of what Kevin mentioned will work dandy. You will end up taking off a lot more than you think you need to
Old 08-15-2007   #4
Re: Installing FMIC
A Rotozip owns metal too. Usually a sawzall or cut off disk work the best.
Old 08-15-2007   #5
Re: Installing FMIC
I had bad luck w/ the rotozip on the 1G bumper actually....skip straight to the sawzall!!!
Old 08-15-2007   #6
blageo23
AWD4G64
blageo23's Avatar
Re: Installing FMIC
I tried cutting one on a 1g and went through 2 discs on my angle grinder. Id say try the sawzall!
Old 08-15-2007   #7
Re: Installing FMIC
I was just going to say angle grinder, but they do use composite discs that are meant to wear down, that's how they make money, you have to keep buying them. The 30 dollar angle grinder is cheaper than a sawzall though.
Old 08-16-2007   #8
Bunta
Bunta's Avatar
Re: Installing FMIC
So where is it that I get this sawzall? I've never seen it before. Where do I get it? Does it need a air compressor? Thanks guys.
Old 08-16-2007   #9
92EvilTalon
3.1L v6 power...
92EvilTalon's Avatar
Pit Stop Challenge Champion!
Re: Installing FMIC
You can get a Sawzall (Reciprocating Saw) at any home center... Here is a link about it.... Sawzall Reciprocating Saw By Milwaukee Tools
Josh LaCroix
Old 08-16-2007   #10
Bunta
Bunta's Avatar
Re: Installing FMIC
So does anyonye have the saw that I can borrow instead of going out there and buying a new one and only using it one time?
Old 08-16-2007   #11
92EvilTalon
3.1L v6 power...
Re: Installing FMIC
Do you own a House? If so you find lots of things to use that with. But if not see if some one else will let you borrow it. Granted chip in for the new blade for it. Or two.
Josh LaCroix
Old 08-16-2007   #12
2.SlowES
2.SlowES's Avatar
Re: Installing FMIC
Go ask your neighbor or a friend. I'm willing to bet someone around you has one.
2.SlowES is offline   Reply With Quote
Old 08-17-2007   #13
dedlewamp
Drives: 4G63
Re: Installing FMIC
Also, a helpful tip. Don't try and cut the entire hole out. What I have found works great is a pair of tin snips. Just make a few cuts around the current hole going outward, then take a hammer and bend the metal backward or forward until the hole is big enough for your piping to go through.
Tin snips are are cheap, but a reciprocating saw is always nice to have around the house/shop.
dedlewamp is offline   Reply With Quote
Old 08-17-2007   #14
Bunta
Bunta's Avatar
Re: Installing FMIC
Well I got the intercooler in and everything. The only thing is the metal on the bumper. I'm working on getting a sawzall or borrowing one to cut that metal piece that is hitting the intercooler, hopefully.
Old 08-17-2007   #15
Re: Installing FMIC
I just left my bumper support off!
Old 08-17-2007   #16
bluntedelvis
Click,Click,BOOM!!!
bluntedelvis's Avatar
Re: Installing FMIC
^+1 and rotozip
