Old 11-04-2007   #1
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Coolant Temp Sensor
What symptoms does a faulty coolant temp sensor cause? Couple of people have suggested this to be the problem for my car but I just don't understand what a temp sensor has to do with how the car runs. Enlighten me if you can!
- Josh L.P.
Old 11-04-2007   #2
Pimpin Dsmstyle
Br0k3N
Re: Coolant Temp Sensor
92 awd turbo talon
- Josh L.P.
Old 11-04-2007   #3
If the coolent temp sensor fails or the wires break the ecu defaults to cold or hot, if it defaults cold it will dump a lot of fuel because it thinks its -40deg out side.
Old 11-04-2007   #4
Pimpin Dsmstyle
Br0k3N
It's running like complete shit until it's up to complete running temp. I think it's getting shitty mileage as well.
- Josh L.P.
Old 11-04-2007   #5
Hook up a logger and see what the ECU thinks the coolent temp is, or just look at your thermostate housing, the ecu temp sensor is the 2 wire one on the bottom pointed down at an angle, the wires could be cracked/broken or the sensor could be bad. If its the wires just cut them back few inches and use spade connectors and new wire, it does not matter which one goes to what terminal on the sensor.
Old 11-04-2007   #6
Pimpin Dsmstyle
Br0k3N
If those wires weren't establishing a connection, wouldn't that not allow my temp guage to work or is that a different connection?
- Josh L.P.
Old 11-04-2007   #7
The temp gauge is the single wire sensor next to the ecu temp sensor, and the other 2 wire sensor on top is for the AC fan.
Old 11-04-2007   #8
There are three sensors on a 1g.
CTS for ECU (lower on t-stat housing, near head, by gauge sensor)
CTS for a/c system fans (higher up on the thermostat housing)
CTS for stock gauge. (1 wire)
Old 11-04-2007   #9
lOL, great timing.
Old 11-05-2007   #10
Pimpin Dsmstyle
Br0k3N
How does that shit come off? is the plug portion of the wires somehow clipped onto the sensor? I was tuggin on it but didn't wanna rip on it. The wires are really stiff but I'd need to disconnect it and get a better look at it to see if it's broken.
- Josh L.P.
