Old 12-05-2007   #1
Gravy
Who's this guy?
14b-16g
After bending one of the center clips on the 16g, i started looking around for the part through FP, and other websites online, with minimal results. Now, to make a long story short and the question as simple as possible.
Is it possible to turn a 14b into a small 16g with just the compressor housing and turbine switched out on the turbo? I've got a rebuild that would be going in, and the the 16g center section may be out of commission until i can get my hands on those parts.
Thanks in advance for any help... turning into an expensive learning process.
Old 12-05-2007   #2
Re: 14b-16g
14b and 16G's are the exact same except for three things:
-compressor wheel (16G is bigger and different design)
-compressor cover (machined to fit each specific wheel)
-turbine housing (14B has a 6cm housing, 16G's have 7cm housings)
I would say slap the 7cm housing on the 14B and let'er buck until you get your 16G back together.
Old 12-05-2007   #3
Gravy
Who's this guy?
Re: 14b-16g
But the small 16g should still ahve the 6cm housing i thought.
Old 12-05-2007   #4
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: 14b-16g
Nope, 7cm
I ported mine out a little and took pictures of the difference between the 16g and 14b. improvement
Old 12-05-2007   #5
Gravy
Who's this guy?
Re: 14b-16g
Well, they say you learn something new every day, this is showing to be true.
