Old 01-03-2008   #1
4Las90
4Las90's Avatar
Drives: Evo 8 RS
Send a message via AIM to 4Las90 Send a message via MSN to 4Las90
AEM Wideband UEGO Gauges Just $254.99 / 5 In Stock!
Click here to purchase one at this limited time sale pricing!
AEM Gauge-Type Wideband UEGO Controller
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
* Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
* Does not oscillate AFR reading like narrow band sensors
* No laptop required for monitoring!
* Bosch sensor included
* Accurate to 0.1 AFR
* Reads in AFR or Lambda via a switch in back of gauge housing
* 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
* Integrated three-digit display reveals AFR or Lambda in real time
* User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
* Serial data stream included for output of AFR (RS 232)
Frequently Asked Questions
AEM FAQs - Gauge Type Wideband UEGO Controller
MAPerformance Purchasing Manager/Sales
P: 763-545-3800
E:bill@maperformance.com
W:www.maperformance.com
AIM: BillatMAP
2004 Lancer Evolution VIII RS
475hp/470tq MAP SST E85!
4Las90 is offline   Reply With Quote
Old 01-03-2008   #2
Dizmm
Dizmm's Avatar
Drives: on ICE
Re: AEM Wideband UEGO Gauges Just $254.99 Shipped!
How long will this sale be going on?
Andy Smedegard
Dizmm is offline   Reply With Quote
Old 01-04-2008   #3
v8klla
v8klla's Avatar
Until we sell the 5 we have in stock
Chris
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 01-05-2008   #4
X Factor
The Newbie
Re: AEM Wideband UEGO Gauges Just $254.99 / 5 In Stock!
I might be interested in one of these... I might have to give you a call, because I have a few other things in mind.
2006 Mitsubishi Eclipse GT
X Factor is offline   Reply With Quote
Old 01-05-2008   #5
v8klla
v8klla's Avatar
Sounds good please do!
Chris
P: 763-545-3800
