Old 01-06-2008   #1
strokerace
Galant VR4 Help
I Just picked up a GVR4 and it sputters-cuts out at 3-4k RPM 0-5psi will go up to 4K rpm's cold and 3k warm.
I did the buzer thing and I got this
Long short
1 1
2 1
2 5
1 1
2 1
2 5
looks like to me a 21 Engine coolant temperature sensor and 25 Barometric pressure sensor or did I read the info wrong? Im working on trying to data log but my old laptop is having issues.....
so far
I removed the boost controller
put in a new fuel filter
new plugs & wires
put on some new couplers
What do you guys think my next step should be?
1991 Galant VR4 #83/2000 Belize Green
strokerace is offline   Reply With Quote
Old 01-07-2008   #2
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: Galant VR4 Help
Check the wires at the coolant temp sensor harness on top of the Tstat housing. They were more than likely broken while you were upgrading
Old 01-07-2008   #3
Re: Galant VR4 Help
Have you done a boost leak test?
Old 01-12-2008   #4
strokerace
Re: Galant VR4 Help
It now holds 25 psi fixed a leak from intake to V/C
the car is very random when it cuts out worst is in fifth gear all I have to do is get in to the pedal and it cuts out.
very random where it cuts out any where from 3-12 psi and 3-4500 RPM
