Old 12-17-2007   #1
Kougar
Drives: 06 RSX
1990 Talon AWD, ~stock, needs work
My financial situation is tighter than I'm comfortable with and I need to get rid of some stuff in order to fix it. This includes this car, since I have a truck that is perfectly capable of getting me from A to B.
1990 Eagle Talon TSi AWD. 145K on car. 5sp, silver/black with grey cloth interior. All stock other than a K&N filter, MBC, Accel 8mm wires, CD player + speakers. Tinted tails, rear side markers, front running lights/blinker assembly, reverse lights. Autometer boost gauge (works), autometer narrow a/f (unhooked) on an A-pillar 2 gauge pod.
Good:
- Nearly rust free (starting to bubble on underside of fenders)
- Always starts
- Engine runs good
- Straight + Balanced 2Ga talon wheels with NEW Fuzion HRi tires on all 4 corners. By new, I mean less than 100 miles.
- Has NOT been modded
Bad:
- Infamous 2nd gear grind
- No driver window motor
- Front wheel bearings bad
**- Front Pass Axle bad
- Clutch going out (still driveable)
- Leaks oil - I know one of the leaks is cooler lines (gaskets at housing) but the front case might be leaking too.
- Struts all torn open; bouncy
- CD player only gets 1 radio station (kinda a shitty deck).
- Crack in exhaust housing of stock turbo.
**- Blower motor doesn't work
- Crack in windshield, does NOT impair vision though
- Dent on rear driver quarter panel
- Pass door handle broken
**Pics are old: Does not show tinted lights, or proper wheels. Pass sideskirt is now installed on car**
Now here's where it gets complicated. Sale of car depends on how fast you want it compared to what all you need replaced. I *plan* on replacing the axle and fixing the blower motor, but I honestly cannot give an ETA on when it will happen. I don't have my tools where I live and no garage to work on this thing. Living in an apartment sucks.
Looking for $2000 with blower motor and axle fixed. Otherwise, $1800 as it sits.
VIN will be given to those who request it. Title is CLEAN.
Contact: Tom at 651 249 5330, anytime - leave voicemail if no answer. Otherwise, PM me.
Old 12-18-2007   #2
Kougar
Drives: 06 RSX
Re: 1990 Talon AWD, ~stock, needs work
I should note that there's the option of putting the old wheels back on. The tires are bald in rear and low in front, and the rims are bent, but it will drop the price by $500.
So, turn-key AWD for $1300!
Old 12-23-2007   #3
driftn1g
this car runs now?? im confused? if your willing to work better then 1300 im interested
Old 12-24-2007   #4
Kougar
Drives: 06 RSX
Yes it runs. It goes from point A to point B, albeit noisy, cold, and slightly dangerous.
I should note that the clutch might NOT be slipping. The axle is probably broken causing the RPMs to rise without car going much faster. Was told clutch was newer, and when I combine that with the known fact the axle is bad, it just makes sense
So if that is the case, I cannot go lower than $1300. I am already losing money on this deal, and it's getting old screwing myself out of hundreds
Old 12-24-2007   #5
jhaan_dude
jhaan_dude's Avatar
Drives: a car
how is the new place treating you? im sorry to hear that the starion went down the road......bring it by i would most definately be interested in it...i have cash on hand thanks to my new job and selling alot of shit around the place (motorcycle and other shit).....call me at 651-459-8433
Old 02-19-2008   #6
Ronnie S
is this still available?
Ronnie S is offline   Reply With Quote
Old 02-19-2008   #7
2.3 Stroker
2.3 Stroker's Avatar
YOu have a spare AWD transmission laying around
Real cars are built, not bought
2.3 Stroker is offline   Reply With Quote
Old 02-25-2008   #8
Kougar
Drives: 06 RSX
Car is sold, no parts left over. This thread can be closed
