Old 03-24-2008   #1
blageo23
AWD4G64
blageo23's Avatar
Need Help With An Open Wire
Alright as many of you know I rewired my whole engine bay, I cut/soldered a ton of wires. I have had no problem EXCEPT my left from blinker doesnt work. I checked the bulb and when that didnt work I put my voltmeter up to it and nothing. So somewhere between the switch and the socket there is an open. That wire goes under the dash out the drive side fender and I believe halfway under the radiator before turning around and going to drive side headlight. So in order to find the open I will have to take the driver fender off and/or the radiator.
Here is the question, Is there a tool that I can find this with easier then using a voltmeter at random locations to find it? and If so does anyone have access to it that is willing to help me out. This wont be for another month or so but I want to plan something out.
Thanks guys!
1998 Spyder AWD
567hp
490tq
Old 03-24-2008   #2
brando
Drives: gutlass
Re: Need Help With An Open Wire
umm you migfht have just fried a wire. look for like bubbles and stuff. also look at where you might have cut it?
other than that i dont know of any other way, but then again ive never really had a problem like this
Old 03-24-2008   #3
blageo23
AWD4G64
blageo23's Avatar
I know I didnt fry a wire. I know there was a time I accidently cut a wire but I did solder it back together. maybe I cut more then one. BUT I found this... anyone use one of these?
http://www.northerntool.com/webapp/w...5011_200305011
1998 Spyder AWD
567hp
490tq
Old 03-24-2008   #4
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
That one is expensive... Go to Menards or Home depot and get one of these. They work wonders and make finding wires very simple.
I have one and it works great. The case opens up with 5 attachments. Also works for phone line outlets and Coaxial cable.
http://www.amazon.com/Gardner-Bender.../dp/B000BO6Y1O
Originally Posted by shoutbox
Old 03-25-2008   #5
blageo23
AWD4G64
blageo23's Avatar
Thanks for the info, does that work with auto stuff?
1998 Spyder AWD
567hp
490tq
Old 03-25-2008   #6
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
It works with anything electrical. There are 2 clips inside the box for bare wires, a needle point for sticking into a wire or harness and the telephone and coaxial cable adapters.
Old 03-25-2008   #7
blageo23
AWD4G64
blageo23's Avatar
Hmm, maybe Ill go there and check it out. Thank you for the info!!
1998 Spyder AWD
567hp
490tq
Old 03-25-2008   #8
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
I have the tool and will give ya a hand if needed just let me know.
Amsoil Dealer
