Old 06-22-2008   #1
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Headgasket break-in period?
I just finished installing a MLS 4 layer headgasket with copper spray tonight. Now I'm wondering how long I should let it break in before I boost the car? My friend used MLS on his GTP and and let it break in for 300 miles. What do you guys think?
-1990 Mitsubishi Cyborg 4WD-
Old 06-22-2008   #2
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
Re: Headgasket break-in period?
I've never broke a head gasket in, as long as you torqued the head down properly you shouldn't have a problem.
Old 06-22-2008   #3
I just replaced my Mitsu MLS with a Mitsu composite gasket. I let the car warm up nice (mainly to make sure there was no coolant leaks or anything) then proceded to beat the hell out of it almost immediatly. It's been holding up fine ever since.
Old 06-22-2008   #4
Check for leaks and drive it like you stole it.
Old 06-22-2008   #5
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Haha alright thanks guys!
Old 06-22-2008   #6
driftn1g
RETORQ your head studs after 100 miles!!
Old 06-22-2008   #7
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I will retorque them after a couple heat cycles about 3 times or so to be sure.
Old 06-23-2008   #8
If you torque the studs right the first time a re-torque is not needed.
Old 06-23-2008   #9
Remember to apply black loctite to the threads and torque to 200 lb/ft.
Old 06-23-2008   #10
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I did do them all in sequence (30-60-80-90) but I always like to make sure. I also threaded them into the block with my fingers in and out about 5 times each to make sure they sat in there good.
Sadly some people would probably do this.. Lol
Old 06-23-2008   #11
driftn1g
don be confusing people !
