Old 06-25-2008   #1
Terryick84
Drives: 1991 eagle talon tsi awd
hard to start?
here's the problem i just installed a wallbro 255lph fuel pump and now it is hard to start it at first but after a few sec of cranking it it starts up, and it runs just fine other than that.
Terryick84 is offline   Reply With Quote
Old 06-25-2008   #2
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: hard to start?
Check to make sure it's holding good pressure. It's possible the o-ring is in wrong or something else is incorrect making it bleed off pressure.
Old 06-28-2008   #3
iceminion
iceminion's Avatar
Re: hard to start?
an adjustable FPR is a really really good idea with such a large pump.
most adjustable FPRs allow you to have a gauge mounted in it.
Buy the above two items and make sure your fuel pressure is at a stock 38psi at idle without the vacuum line connected.
get back to us when you get that done.
building a 3000GT AWD Turbo.
