Old 06-03-2008   #1
LaunchHard
LaunchHard's Avatar
Oil leak from timing belt side
Theres an oil leak coming from the timing belt side of the engine. It looks like its coming out near the tensioner. I was told that oil can actually leak out of the tensioner bolt, but there is a fix for it. The leak is pressurized, as the revs go up the leak becomes heavier. Any ideas?? Its not the valve cover and not the oil pan. what can leak between there???
Thanks for the help!!!!!
Old 06-03-2008   #2
Re: Oil leak from timing belt side
If this engine has no balance shafts there is a pulley/tensioner bolt that needs rtv on its threads or it will bleed oil.
Old 06-04-2008   #3
LaunchHard
LaunchHard's Avatar
There is a balance shaft in the engine. But i'll try the rtv on the bolt anyway.
Any other suggstions???
Old 06-05-2008   #4
Possibly a seal? Maybe the front cover seal, or oil pan?
Old 06-30-2008   #5
allyoucaneat_talon
allyoucaneat_talon's Avatar
Drives: 93 Talon Tsi AWD
My is leaking that like tooo and i'm trying to find out what the crap is leaking... I took the balance shaft off and seal the oil pan but it still leak. I think it's the front case or maybe the balance shaft bolt, i will check it this weekend.
95 Talon Tsi= SOLD
92 Mitsu Gsx= SOLD
