Old 07-11-2008   #1
eweppler
eweppler's Avatar
Drives: 92 Talon TSI AWD, 07 Honda Civic EX
Need Help! Acceleration Hesitation.
I have a 92 talon tsi awd and i am experiencing some engine hesitation upon acceleration. My first thought was that the transmission is going out but i have taken it to a couple of places and they tell me that the tranny is fine. Then i noticed that i have a boost leak somewhere. Every once in a while when i come to a complete stop the car will die on me as well. Could this be caused by the boost leak.
I looked at my hosing and i noticed that my air intake hose between the air filter and the turbo is broken where the bypass hose connects to it. Will this problem cause anything, I was told to possibly just block that off and let the bov dump into the air.
eweppler is offline   Reply With Quote
Old 07-11-2008   #2
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Need Help! Acceleration Hesitation.
Replace it... Dont block it off. Test for boost leaks again.
Originally Posted by shoutbox
Old 07-12-2008   #3
eweppler
eweppler's Avatar
should i go with a stock or aftermarket one. Not planning on spending too much on it.
Old 07-12-2008   #4
eweppler
eweppler's Avatar
Here are some pictures of the problem i have come across. The bypass hose is just sitting loose in the air intake hose.
http://s228.photobucket.com/albums/e...alon%20engine/
Old 07-12-2008   #5
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Replace it with stock if you are on a budget.
Linky no worky...
Copy and paste the link from photobucket again.
Old 07-12-2008   #6
x3 On to just replace the CBV tube. Sounds like you have a vented bov to atmosphere and the vehicle doesn't like the unmetered air going into the atmosphere (let alone the air leak behind the MAS sensor).
