Old 03-08-2004   #1
-GSX-Falcon
Guest
Tournaments Won: 6
Posts: n/a
Ok,
I am having a suspension problem. I have started to have a tick (just in the last week) coming from my car when I drive. Sometimes it seems to go away, other times its very annoying. I swear at times i can feel it "tick" in the steering wheel but I may be crazy. When its acting up it gets really mad when i take a left turn. I suspected something was hitting on my Passenger front rim/tire...but I took the rim off and everything looked ok. Any ideas as to what it is. Im hoping it just needs a good lube or something (does not look like it has had one in awhile)
Old 03-08-2004   #2
Are either of your CV boots cracked/broken?
Old 03-08-2004   #3
520Talon
Check your cv boots and see if they are torn. That sounds like a suspect CV joint.
520Talon is offline   Reply With Quote
Old 03-08-2004   #4
-GSX-Falcon
Guest
Tournaments Won: 6
Posts: n/a
Where is it located/look like so i can check it out.
Old 03-08-2004   #5
The rubber boots on your front half-shafts (axles).
Old 03-08-2004   #6
-GSX-Falcon
Guest
Tournaments Won: 6
Posts: n/a
Thats what it is. I can move that up and down the axle on my passengers side. On the drivers is sealed onto something. How do i fix?
