Old 06-11-2006   #1
SLOW_V
stripped water line threads
I was installing my 14b last night on my 1g fwd. The bolt is in but not tight. I would asusme it would leak. Anyways, I stripped the coolant water line threads from the head? The bolt itself is not stripped? Any suggestions? Could I retap the hole the same size or I need to retap it lil bigger?
SLOW_V is offline   Reply With Quote
Old 06-11-2006   #2
blageo23
AWD4G64
blageo23's Avatar
Re: stripped water line threads
There is no coolant line from the head, there is an oil line from the head and the coolant lines go to the big water line and the water neck. If it is the oil line on the head(left front top of head) then alot of people would say to take the head off and helicoil it. Me and a freind helicoiled his with the head on and had no problems.
Old 06-11-2006   #3
SLOW_V
My bad, I thought it was the water line? What is Helicoiled? Anyways, thanks for the advice.
Old 06-11-2006   #4
Originally Posted by SLOW_V
What is Helicoiled?
http://www.emhart.com/products/helicoil.asp
Old 06-11-2006   #5
SLOW_V
Originally Posted by Jakey
Thanks Jakey!
Old 06-11-2006   #6
Thanks Jakey!
Google is your friend.
Old 06-11-2006   #7
blageo23
AWD4G64
blageo23's Avatar
Pretty much you tap it a bigger size and the helicoil threads into. Then you can reuse the bolt because the helicoil make it the same size as it was(you need to find the right helicoil). End result the same size/pitch hole and helicoils are WAY stonger then aluminum.
Old 06-13-2006   #8
Remember, that is a banjo bolt you are cranking on. Anytime I've ever re-installed one of those, it was old and weak and the head broke off. This might be what you are experiencing. A replacement banjo bolt from mitsu is like $10.
Old 06-15-2006   #9
SLOW_V
If this is the case and it works. I will send you a case of beer!
If not, then I am going to send you a bill via paypal for $10.
Old 06-14-2006   #10
SLOW_V
If I plugged this up, is there another source where I can pull oil to the turbo?
I noticed there is another plugged right below the water coolant neck? It looks similar to the 2g oil spot? Could I used this instead????
Old 06-15-2006   #11
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
wow, this is weird. We had this problem last night with Tauni's car. Does anyone have a helicoil we could borrow to fix hers?
Old 06-15-2006   #12
SLOW_V
You don't borrow the helicoil. It is an insert that you tapped/screwed into the stripped thread.
That oil plug/bolt by the oil filter house is a PITA to take off. You will need allot of muscle to take it off. Is there another source I could use?
Old 06-15-2006   #13
You can also pull oil from the oil filter housing, which is generally recommended, and makes install/removal easy as pie.
Old 06-15-2006   #14
s1ngletracker
Drives: A BMW
is there a plug or something that you can take out and just thread in a barb or something? how does that work?
Old 06-15-2006   #15
s1ngletracker
Drives: A BMW
I know what a helicoil is... but I thought you needed a special tool to actually install one? I realize there is a coil that must stay in there, but usually a helicoil kit comes with a whole bunch of it.
Old 06-15-2006   #16
x-pride
x-pride's Avatar
Don't the 90 DSM have a different oil housing than the 91-94?
Old 06-15-2006   #17
A helicoil kit comes with the inserts and the tool to install them.
Old 06-15-2006   #18
s1ngletracker
Drives: A BMW
is there an oil plug or something I could use for an oil source in a 90 housing? And if I could get a thread size so i can get a brass fitting that would help out too thanks guys. Trying to help Tauni get back on the road ASAP, and her car out of my garage.
Old 06-15-2006   #19
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Just an FYI, if you do end up having to retap the hole make sure you don't use a fine thread. I can tell you from experience that it will strip very easy. Also PVT is amazing!
pics or gtfo
Old 06-15-2006   #20
SLOW_V
I'm going to take the ez way out. I'm going to super glue the shit back!
