Old 10-08-2008   #1
DSM_ROOKIE
Drives: 1993 mitsubishi eclipse GSX
question about installing turbo timer?
i got a 93 GSX and wanting to put in my turbo timer but got a little problem and couldn't figure out why. i install it like the manual say to install it, i put the black wire for ground, gray wire for the ebrake and i use an evo 8 harness that i got from a friend for the plug and play and the timer wouldn't turn on. i was wondering if the evo 8 harness is the problem? if any body out there can help me out that would be great.
DSM_ROOKIE is offline   Reply With Quote
Old 10-08-2008   #2
Re: question about installing turbo timer?
Here's my advice. Sell the turbotimer on ebay, put the money towards more fun stuff that will actually do something on your car
Old 10-08-2008   #3
sleepy2lazy
sleepy2lazy's Avatar
Maybe you didn't put the ground wire in correctly or in the wrong spot?
I know when i did mine, if was a bit loose, it wouldn't turn on.
I've never heard of an evo harness being used so that could also be the problem.
a TT is somewhat useless, unless you drive your car hard all the time.
The $100 bucks or so that you spent could be saved and spent elsewhere.
Old 10-08-2008   #4
I believe the Evo shares a harness with the 2G, not 1G's. Buy the proper harness for $10-15 and you'll be set.
