Old 10-09-2008   #1
OmgAwd
OmgAwd's Avatar
Drives: 1992 Eagle Talon TSi Awd
Unique turbo Questions
Will the seals from a 9b work on a 13g?
Running 16psi on a 13G, will i gain anything by upgrading my intercooler form the stock side mount to an FMIC or larger SMIC?
OmgAwd is offline   Reply With Quote
Old 10-09-2008   #2
Re: Unique turbo Questions
A FMIC will always help. Don't worry about the seals on a 13g, just get a used 14b. It is quite a bit bigger and they are cheap.
Old 10-09-2008   #3
+1
Old 10-09-2008   #4
CarPsyco84
CarPsyco84's Avatar
not as much as going to a 14b or even a 16g would make...
-When in doubt, Moar RPM.
Old 10-23-2008   #5
OmgAwd
OmgAwd's Avatar
Still wondering about this. I've got a couple of good 9b's laying around and a blown 13g in my car. I'm not going to upgrade if i can use those seals.
Old 10-23-2008   #6
have you ever rebuilt a turbo? you do know it has to be reblanced after you take it apart. It will be a hell of alot cheaper to pick up a 14b or a 16g and a 2g manifold
Old 10-23-2008   #7
OmgAwd
OmgAwd's Avatar
Not when you include the cost of injectors. My 390's won't keep up with a 14B.
Old 10-24-2008   #8
2bar1g
Member
Drives: .
I'm going to disagree with you omgawd. A 14b and 2g mani can be obtained for less than a 100. Pick up some 450s, 5speed ecu, and a 5speed FPR. All of that can be bought for around 175 and then you'll be making mad powa.
2bar1g is offline   Reply With Quote
Old 10-24-2008   #9
brando
Drives: gutlass
what he say's
its not worth doing the rebuild on a 13g. they are just shit turbo's
