Old 10-22-2008   #1
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
2g Knuckle Kit
Just a few quick questions for all the DSM guru's or anyone else for that matter. Are all 2g DSM (95-99) gsx/gst front knuckles the same? Or is there a difference between 2ga and 2gb? And finally, is there a difference between ABS and non-ABS versions, also 2ga and 2gb?
Avatar = Small Turbo:confused:
mukapahnpy is offline   Reply With Quote
Old 10-22-2008   #2
Re: 2g Knuckle Kit
There is a difference between ABS and non-ABS versions.
All 2g turbo knuckles should be the same though, doesn't matter gst/gsx. Not too sure about gs/rs though. I know 95/96 Chrysler Sebring/Doge Avengers knuckles also work on the 2g's. I've got a sebring one on mine currently.
Old 10-22-2008   #3
Re: 2g Knuckle Kit
They should be the same for the n/t versions as well.
Old 10-23-2008   #4
Re: 2g Knuckle Kit
they are all the same rs-gsx
just diffrent for abs or no abs
Old 10-29-2008   #5
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
Re: 2g Knuckle Kit
Thanks for the info guys!
Last question. If i broke the ABS sensor, does it matter if I replace it or not? If I don't replace it, will it have and adverse effect on the rest of the sensors / drive ability (given they all still work)?
Old 10-29-2008   #6
Re: 2g Knuckle Kit
If one sensor is out the whole system goes down.
Old 10-30-2008   #7
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
Re: 2g Knuckle Kit
hrm...
ABS needed or not?
Would YOU replace it?
Old 10-30-2008   #8
Re: 2g Knuckle Kit
ABS is for pussies. hahaha I wouldn't worry too much about it if it was my car. I'm not sure how it is on a 2g, but I've heard the ABS system on 1gs sucks balls, and considering some of Mitsu's other early ABS systems, I wouldn't think the 2g's is much better.
