Old 05-30-2010   #1
C89ZX7R
C89ZX7R's Avatar
Drives: 87 and 89 Chrysler Conquest
Rebuilding the 87 Conquest TSI
Picked up a 87 Atlantic Blue quest two days ago around midnight. Its just a roller. Has dings which looks to be from hail on the roof and the hood. Had some squirrels living in it, found some acorns in the glovebox and under the wiper cowl. Plus the carpet had what looked to be squirrel shite all over it. The following day I started to remove the front end for small rust repair.
Fixed some rust and used rubber undercoating in the fender wells and on the frame rails. Then sprayed the front section and engine bay rails down with black rustoleum paint.
Edit "Friday April 29th 2011" Mod List Below
Rebuilt Bottom End, Stedebani 95A Motor Mounts, Balance Shaft Elimination, Jet Valve Elimination, Throttle Body Rebuild, Krank Vents, MK1 Egr Block Off, GM Delphi Injectors, GM 110 Amp Alternator, Alternator Ground Strap, Transmission to Firewall Ground Strap, Dual Alternator Charging Harness, Optima Red Top, 1G Maf, TD05-12A, KDM Turbo Small Discharge Pipe, KDM Turbo Inlet Pipe, TEP Ovcp w/ Turbo-Xs Type H Bov, 14.5psi Boost Pill, 2.5" Catless Turbo Back, Stock Twin Tip Muffler, 83 Starion 2 Piece Crank Pulley, Rodded Stock Radiator, Accel Yellow Coil, Accel 8.8 Wires, Fram Oil Filter, Rotella T6 Full Synthetic, New Coolant Temp Switch, New Master Cylinder/Water Pump, A/C Delete, Abs Delete, Star-Orion Abs Line, Steel Braided Turbo Oil Feed Line, Charcoal Canister Delete, Anti-Roll Over Valve, 89 Ecu, 89 Airdam, 89 Rear Starion Shoulder Belts, 89 Rear Seats, 89 Hvac Panel, Grant Steering Wheel, Stedebani Short Shifter, Eibach Rear Lowering Springs, Suspension Tech Front Lowering Springs, Shp 8 Way Front Struts, Kyb Gr2 Rear Struts, 90/100 Watt Relayed Headlights Harness, H4 Headlight Housings, Silver Star H4's, 55 Watt Foglight Bulbs, Foglight Mod, Resprayed Flat Black.
Motor Is Tight, Sounds Unbelievably Badass, Intimidates Slow Hondas Instantly
C89ZX7R is offline   Reply With Quote
Old 05-30-2010   #2
Re: Rebuilding the 87 Conquest TSI
Not bad looking
But stop using bold type. Reg. Is just fine
Old 05-30-2010   #3
C89ZX7R
C89ZX7R's Avatar
Not bad looking
Fixed
Old 06-01-2010   #4
C89ZX7R
C89ZX7R's Avatar
Tuesday will bring
Pulling the dash
Upgrading the Ecu harness from 87 to 89
Engine bay painting
Hopefully wire tuck both harness's!
Old 06-02-2010   #5
C89ZX7R
C89ZX7R's Avatar
Was raining on Tuesday. Removed some more parts off the 88 parts car to get it ready to be picked up by the body guy. Replaced the sunroof shield on the 87 project. Also cleaned under the wipers and removed the squirrel shite and acorns from that area. Hopefully I will be able to finish the engine painting on Thursday and replace the rotors and pads. Ordered a Star-Orion "Abs" bypass line and a Mokeeh Egr block off last night.
Old 06-03-2010   #6
C89ZX7R
C89ZX7R's Avatar
Sprayed the rest of the bay, then it rained a few hours later. It was dry by the time it started to rain.
Old 06-03-2010   #7
C89ZX7R
C89ZX7R's Avatar
May use "Monstaliner" on the exterior of the car, will be using it to replace the carpet!
Example pic on how this stuff looks!
Old 06-09-2010   #8
C89ZX7R
C89ZX7R's Avatar
Bolted on a few front end parts, added some drilled/slotted rotors, a Star-Orion abs bypass line and some new brake pads.
Old 06-09-2010   #9
I'll sell you a brand new airdam just spray painted black for $200 bucks plus $20 for shipping. That's way better than you will find elsewhere, as far as I know.
Old 06-09-2010   #10
C89ZX7R
C89ZX7R's Avatar
Black car has a brand new freshly painted 88-89 airdam.
Old 06-09-2010   #11
Not the blue car though.
Old 06-10-2010   #12
C89ZX7R
C89ZX7R's Avatar
Black one has turned into the donor car for the blue one.
Old 06-10-2010   #13
C89ZX7R
C89ZX7R's Avatar
Pain in the ass "one" piece exhaust!!!
Pulled the rebuilt motor from the 89 Conquest.
MK1 Egr Block Off Plate Installed
Almost in, angled motor mounts are a pain in the ass. Of course so is gravel, grass and a engine lift.
Bolted down!
Old 06-10-2010   #14
DSM_brother2
Drives: to the shop
looking good!!! i want one so bad
93 talon tsi/ 6 bolt swap
Mitch
Old 06-15-2010   #15
C89ZX7R
C89ZX7R's Avatar
Removed the old nasty odor stinking insulation from under the dashboard! Squirrel Shit Filled Dash, A/C, Heater Core, Blower Motor and Insulation has been trashed.
Old 06-21-2010   #16
C89ZX7R
C89ZX7R's Avatar
Interior is 99.9 percent completed
Old 06-21-2010   #17
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Wow a fast and intteresting project build. I like it!
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 06-21-2010   #18
Keep up the good work!
Old 06-21-2010   #19
Those seats remind me of those super puffy winter jackets people always wear.
Old 06-24-2010   #20
C89ZX7R
C89ZX7R's Avatar
Installed the one piece exhaust, had to use the engine lift to lift the entire car up in the air to do so.
Isc, Tps and Dist plugs needed to be added to the harness.
Wiring fun!
Finished the wiring.
