Old 07-03-2009   #1
2g Monson
2g Monson's Avatar
Drives: 1995 Eclipse GST
02 sensor question
I just got my glowshift wideband today, and it comes with an o2 sensor. Can I just put that in place of the stock one? Will it effect the computer if I take the stock out for the wideband gauge?
2g Monson is offline   Reply With Quote
Old 07-03-2009   #2
Re: 02 sensor question
Leave the stock one in there and hooked up. You don't want your wideband sensor that close to the engine anyways, it will get too hot and burn up. most people run theirs farther down in the downpipe. 12"-24" seems to be about the closest to the turbo that people put them.
Old 07-04-2009   #3
Put it in your rear (cat) o2 sensor bung.
Old 07-04-2009   #4
2g Monson
2g Monson's Avatar
So if i put it in the rear one would it still be as accurate if I were to put it in the down pipe?
Old 07-04-2009   #5
Yes, it'll be fine.
Old 07-04-2009   #6
2g Monson
2g Monson's Avatar
alright sweet, thanks very much
Old 07-05-2009   #7
2g Monson
2g Monson's Avatar
So i got another question, do i have to leave the stock one up top in? So if I put the other one somewhere i would have 3 sensors in. How does everybody else have theirs set up?
Old 07-05-2009   #8
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
I have a AEM that I'm going to be hooking up and I read its suppose to be 18 inches from turbo
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 07-05-2009   #9
2g Monson
2g Monson's Avatar
yeah my glowshift one says no less then 36 inches from exhaust port
Old 07-06-2009   #10
You have to leave the front one in, because the ECU uses that one to determine AFR.
Old 07-06-2009   #11
Yup.
The rear o2 sensor is just for emissions so you can remove that one and disable it in your ECU (if possible).
