Old 04-03-2004   #1
Khadgar
Can't Actually Wrench
Send a message via AIM to Khadgar
I've heard that with an aftermarket clutch, it is normal for it to sometimes drop to the floor and has to be pulled up. I was letting my friedn drive and it happened to him, it was when making a right hand turn/going straight.
Khadgar is offline   Reply With Quote
Old 04-03-2004   #2
john
Business as usual
john's Avatar
Mine only did that when the clutch went out. I would check your fluid and make sure it is full. I haven't heard of the aftermarket clutch idea though.
97 Viper GTS
Old 04-03-2004   #3
It's not the clutch unless it's completely crapped out. Sounds more like a bad master cylinder or possibly the slave cylinder.
Old 04-03-2004   #4
Jacek
Captain J-Sack
mine did that when i was bleeding it after installed a new clutch. sounds like somethings leaking.
Old 04-03-2004   #5
Khadgar
It's a new clutch and I don't have my SS line in, it's has only done this once, I was just curious to whether or not this is normal to happen every once in a while.
Old 04-03-2004   #6
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
:woowoo:
Old 04-03-2004   #7
blown_turbo_tsi
Guest
Tournaments Won: 6
Posts: n/a
it could happen! :goodluck:
Old 04-03-2004   #8
Khadgar
I made sure it wasn't a left hand turn...and if it walks, so be it.
Old 04-03-2004   #9
Rebleed your master cylinder and all should be good.
Old 04-04-2004   #10
Did you get the little locating sleeves back in the tranny? Is the tranny loose at all? They can both do that, don't ask me how I know!!
Old 04-04-2004   #11
Khadgar
Trannys liek it always been
