Old 11-04-2009   #1
CarPsyco84
CarPsyco84's Avatar
wideband bung question.
I just bought a new Innovative DB wideband kit. I have a question about the sensor bung that I'm supposed to weld into the downpipe, It seems it is alot longer than it should be, like the sensor would not be even in the flow of the exhaust. is that how it should be?
-When in doubt, Moar RPM.
Old 11-04-2009   #2
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: wideband bung question.
How long is it? Like a quarter inch? If so that's fine. If you're worried about it go to napa and they carry a nut about 2/16th's thick for o2 sensors.
-1990 Mitsubishi Cyborg 4WD-
Old 11-04-2009   #3
CarPsyco84
CarPsyco84's Avatar
its a 1" long tube with the threads in the middle.
Old 11-04-2009   #4
CarPsyco84
CarPsyco84's Avatar
This is a picture with the sensor screwed into the bung, the sensor doesnt even stick out past the bung, doesn't look like it would meter well like that.
Name:	O2 sensor.JPG
Old 11-04-2009   #5
Kasey at MAP
Drives: E-85 '03 Evo
Send a message via AIM to Kasey at MAP
That one does look a little long.
Kasey at MAP is offline   Reply With Quote
Old 11-04-2009   #6
CarPsyco84
CarPsyco84's Avatar
lol, thats what I was thinking, so I should maybe turn that down to say half that long?
Old 11-04-2009   #7
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Yeah it should only be like a 1/4 of an inch if that.
Old 11-04-2009   #8
CarPsyco84
CarPsyco84's Avatar
Well I guess its the extended length one, looked on innovate's site. Why it's extended im not sure... O well, I guess I'll make 2 bungs out of this.
Old 11-04-2009   #9
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
They make the extended ones for obd2 cars when you take out the cat. So the rear o2 doesn't set off the cel. But, why they sent it with your wideband. I have no clue..
Old 11-05-2009   #10
mdost03
Sonic Champion!
Drives: VA STI
Just got to an exhaust shop or one of the vendors, I'm sure they have plenty of bungs that they can sell for fairly cheap.
Old 11-05-2009   #11
Got one at oreilly for $2.
Old 11-05-2009   #12
It may be there attempt at making the sensors last a little longer. You can cut that down or buy a shorter one. The ones I use are about 3/8" or so.
