Old 12-09-2009   #1
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Idle air controll motor
As it is getting colder and colder my car wont start or stay running do to the fact the idle air control motor has been deleted. So i am in need for a New or used motor for a 1991 eagle talon tsi awd Turbo ^_^
Please send me PM. I need one as soon as possible
Old 12-09-2009   #2
93gtpeater
Drives: cbr 1000rr repsol
Re: Idle air controll motor
Pm sent
Old 12-10-2009   #3
Have you tried adjusting the Base Idle Set Screw ?
Old 12-10-2009   #4
This. The BISS can be adjusted to allow a cracking of the throttle plate. This will allow you to get more air in for cold starts, but be advised it will raise your baseline idle, which can prove to be annoying to some.
Best bet is to get in a working IAC and make sure you BISS o-ring is good without leaks.
Old 12-10-2009   #5
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Thanks Everyone. For the advise again. I figured adjusting the screw slightly for a higher idle at around 1500-1700. Close to guaranteeing a start up. Install the IAC and hope it will help in keeping the motor running.
Old 12-10-2009   #6
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
PM Replied.
