Old 09-19-2010   #1
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Miata+4g63+T56=awesomeness!
I am currently researching this project.
I am currently building a narrow block 4g63. I plan on using a T56 transmisson but could also opt for a T5. I have researched the FC transmission from a turbo rx-7. It would be a lot easier if I could find a wideblock 4g63 or 4g64. I have not started looking into rear ends but I could imagine I could have a huge list of possibilities. I want the car to hook up and hopefully with the right combination of tranny/rear end I could end up with some high top speeds also. haha! I plan on spinning the motor to well into 9000 rpm and making 400-500 HP with a 35R or maybe 50 trim?
I have a couple of questions:
What do current owners of a T56/FC/T5 know about them? Power levels? TQ holding? possible to spin to 9000RPM?
should I use solid motor mounts?
Will evo intake manifolds bolt onto a 1g/2g 4g63? I have some rerouting to do with the manifolds but oh well they will be getting replaced anyway.
Any other comments/suggestions welcome!!
Discuss,
Colin
Old 09-19-2010   #2
Re: Miata+4g63+T56=awesomeness!
the rear end that is pretty much a bolt in is the Ford 8.8 out of a thunder bird with disk brakes
Old 09-19-2010   #3
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Is that possibly the same 8.8 that is in the CTS-V? I have heard the CTS-V one works as well and is stronger than the thunderbird one.
-Colin
Old 09-19-2010   #4
Awesome, would love to see a Miata rock'n a 4G63!
Old 09-19-2010   #5
Don't use the 04/05 CTS-V rear diff, the case is not strong. The 06/07 is a bit stronger though. Maybe you're talking about an 09+ rear diff, but I imagine those are $2k+ and impossible to find used.
My T56 is holding 520wtq, and I know a few V guys are running at least 600wtq on them without any issues, never revving past 6500-7000rpms though. I bet the Viper guys spin them faster, but the Viper spec ones are pretty spendy. Maybe slowbubblecar can chime in on those.
Old 09-19-2010   #6
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
I am not worried about the T56 not holding the TQ/HP goals I have. I am concerned about the ability to spin it to 9000+ Maybe I will just back down the RPM and increase the boost? I want something a little more driveable than a stock tranny DSM gear ratio. I figure the gearing on a T56 is a little longer and will be able to utilize my goals better.
Do you happen to know the ratio for the CTS-V rear end by chance?
-Colin
Old 09-19-2010   #7
I would knock down that 9000+ by at least 1000rpm. You can not have your cake and eat it too, any setup that will make street able power should not be reving to 9000rpm+. If you have full boost before 5000rpm there is no reason to want/need to rev past 8500rpm. If you are looking at a 50trim, then plan on shifting around 7500rpm, a 35r is a lot bigger and will make/hold power to about 8500rpm. I am basing these numbers on a 2.0, if you have a 2.3/2.4 then knock the rpm down again, by about 15%.
Old 09-19-2010   #8
Just get a g54b, I have one attached to a conquest that I'll sell you for 7 grand.
Old 09-19-2010   #9
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Yeah I was thinking the same thing. I really don't need to make that much RPM but it would be nice.
Hopefully I'll opt for the 35R. That should get me the goal power I want and maybe some more room to grow?
It will be a built 2.0.
-Colin
Old 09-19-2010   #10
Sickness. I would love to see this happen.
Old 09-19-2010   #11
If you're not going to rev the piss out of the thing, why not go 2.3 or 2.4?
Old 09-19-2010   #12
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Well I already have a 2.0 block.. I would have to do a TON more research on the 2.3 or 2.4 if I went that way. I already have eagle rods and wiseco pistons for a 6 bolt 2.0
-Colin
Old 09-19-2010   #13
travail
travail's Avatar
Drives: EV0 8
AAAMMM no they don't. The miata are a IRS rear and not a sold axle. I would just use a RX7 turbo 2 rear end they have 4.10 gear and a LSD in them all and they are a TRUE bolt in and they are just as strong as a Chevy 10 Bolt.
here
http://cgi.ebay.com/ebaymotors/Mazda...item483baa1b59
travail is offline   Reply With Quote
Old 09-19-2010   #14
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
I haven't heard any tranny issues for people making less than 750 whp or so. The only people worried about trannies at the TT guys and some of the Paxton people that are making 800 whp+. Used trannies usually go for around $1,500.
The Viper T56 would likely be more than what would be needed in a miata with a 35R.
7/25/09
Old 09-19-2010   #15
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
I don't know if that FC rear end would fit. I think its just the N/a rears that fit. something about the housings? Who knows I have to look into that a lot more.
-Colin
Old 09-19-2010   #16
Turbo.. Billet 6262
Old 09-20-2010   #17
here
I do know what I am talking about I have looked into this a lot since my dad wants to put a ls in his car and a ford 8.8 thunderbird rear end and they are IRS just like the miata. It is also a bolt in with a few brackets that you can buy http://www.bossfrog.biz/Miata_V8_Swap.html or build your self
Old 09-20-2010   #18
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
I dont need that much power from a billet 6262.
-Colin
Old 09-20-2010   #19
A thunderchicken 8.8 diff doesn't have LSD, never did. Only the solid axle 3.8L SC did. You can buy an LSD center for the Tbird, but it's pricey. I'd just start with one that's already LSD.
Old 09-20-2010   #20
travail
travail's Avatar
Drives: EV0 8
-Colin
Any of the rear end will work. The turbo 2 and the GTU have a 7inch ring gear were the na is smaller. But the mounting points are still the same as in it the same size as the miata rear end..
To me a true dolt in to me is were you don't have to buy any thing to make it work. The rx7 rear diff will bolt in with out ANY extra parts and i was thinking that the Thunderbird were a sold axle. Sorry if I sound like a ass I have seen other guys on the v8rx7forum do the v8 miata swap and I look in to it years a go and they all most always use the turbo 2 rear end or they do a sold 8.8.
