Old 02-22-2010   #1
Chim55117
Drives: 2007 BMW 335i Coupe
1G-A 6 Bolt 4G63 Shortblock
Disclaimer:
Due to the nature of these parts, the buyer understands that these parts will be SOLD AS IS. The seller assumes no responsibility for any problems that may arise, as neither item has been run while in the possession of the seller.
Posted 2/22/10
Description:
Up for sale today is what appears to be a low-mileage 6 bolt block (stock) from the 1G-A we are parting out. The crank turns freely, and the cross hatching is consistent. It has been rebuilt or refreshed at some point, as the block has been recoated at some point. Approximate mileage is unknown at this point.
SOLD
Also have a 1991 5-speed manual 1G-A transmission, never tested, as we received the car only partially assembled.
Asking 250.00.
Chim55117 is offline   Reply With Quote
Old 02-22-2010   #2
Re: 1G-A 6 Bolt 4G63 Shortblock
Aren't the arrows on the pistons supposed to be pointing to the front of the engine? (timing belt side) I could be wrong.
Old 02-22-2010   #3
CarPsyco84
CarPsyco84's Avatar
I would assume the bigger valve relief's in the pistons belong on the intake side, like in this case...
-When in doubt, Moar RPM.
Old 02-22-2010   #4
Chim55117
It is facing towards the timing belt. Refer to the picture. We never managed to pull compression numbers, as there was no actual way to crank the car. The electrical harness is a hackjob on the car.
Old 02-22-2010   #5
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
You guys able to get any good compression numbers on this at all?
7/25/09
Old 02-23-2010   #6
Chim55117
Tranny sold. Close.
