Old 03-28-2010   #1
Thumbs down My Recently Blown Up Shep Stage 3
Let pictures do the talking
Those two gears have a bunch of broken teeth. Is that fourth gear?
Think the teeth sheared off, got stuck behind the ring gear and blew out the case there?
Old 03-28-2010   #2
Re: My Recently Blown Up Shep Stage 3
That is shitty. Shep going to do anything for you about it?
Old 03-28-2010   #3
CarPsyco84
CarPsyco84's Avatar
And you say I'm hard on transmissions...
Edit, I thought you had a stage 4 trans... or is this another trans you broke already?
-When in doubt, Moar RPM.
Old 03-28-2010   #4
No, this is one I bought new like 3 years ago, has about 15,000 miles on it. Maybe 5,000 miles of 400ish whp. I will be emailing/calling them just to see what they say.
Old 03-28-2010   #5
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
WOW that's crazy. How does that happen? Launching it to much or daily gear grinding. I really would like to know what my tranny looks like inside.
Old 03-28-2010   #6
CarPsyco84
CarPsyco84's Avatar
too much torque lol. yours looks like that, except with all the teeth still there.
Old 03-28-2010   #7
CarPsyco84
CarPsyco84's Avatar
oh ok, so this is the old one you blew up.
Old 03-28-2010   #8
Wow, that's pretty crazy. I wonder what shep will do for you.
Old 03-28-2010   #9
DSM_brother2
Drives: to the shop
hopefully they will, thats nuts
93 talon tsi/ 6 bolt swap
Mitch
Old 03-28-2010   #10
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
You can see some of the teeth are discolored. If that was due to heat wow. When i didnt know what i was doing, sharpening a drill bit in school. It had those exact same color spots as those teeth lol
Old 03-28-2010   #11
They are not discolored. No signs of heat, no blueing, nothing. They just snapped off or something got in there.
I remember I heard a weird noise as I came to a stop, clutch in. Like a quick grinding. Car drove fine for a bit after but stated making a weird noise. I thought it was engine. So my solution? Took off from a light and try to go into fourth, that terrible loud grinding noise, like a gear trying to mesh with a fast spinning gear and not working. I babied it, as I was like a mile away from home, and everything was working as normal except 4th.
Then the next morning I went to inspect and huge puddle of gear lube under the car, and I saw broken case. Then I said, welp, there goes $2000....
Old 03-28-2010   #12
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Was this during normal driving, NLTS'ing or just a hard pull in 3rd/4th?
-1990 Mitsubishi Cyborg 4WD-
Old 03-28-2010   #13
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
ouch. hope everything goes well for you man.
ლ(ಠ益ಠლ)
Old 03-28-2010   #14
First picture looks like wolverine took a slap at it. Pretty cool looking though. Sucks about the tranny.
Old 03-28-2010   #15
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
That's really f*cked up then if it was just normal driving and all that carnage happened. I hope Shep will do something for you in this case.
Old 03-28-2010   #16
How much power?
Fluid?
U drive it like your company car?
Looking for a replacement?
Sorry to hear you are having terrible luck with these things.
Old 03-28-2010   #17
blackrosenova400
blackrosenova400's Avatar
That is fourth gear, which is the most prone for breaking. It is because nobody ever tromps on it in 5th, so fourth gear gets the most load behind it.
It appears it chipped off, then its teeth got behind your front differential and cut your tranny.
20g Mafia
Old 03-28-2010   #18
I've heard about that, and guessed that happened here. But I thought that only happened to higher hp/tq cars?
And yes, I beat on this thing sometimes.
Used Penzoil Syncromesh. I have tried the redline cocktail and didn't like it.
Old 03-29-2010   #19
santa
Boost Spike
santa's Avatar
That syncromesh is terrible for our transmissions. Redline light weight shock proof is what Shep tells everyone to run now. I've had it in my trans for the last two summers and its made a huge difference!! Sorry to see your trans failed!! I've been talking to Shep for the last couple of weeks about trans options for my car. He said, if I went with a stage 4, that I'd get like 100-200 passes out of it. Then he said that I should send it back to him and have the 4th gear replaced. I'm seeing why he suggested that now. Good luck bro!!
Old 03-28-2010   #20
LingLing
AznKraut
LingLing's Avatar
Ouch. That's a lot of money right there. Sorry to hear Welcome to the club of broken transmissions. haha
