Old 11-02-2009   #1
shayne92
Drives: soon to be talon :)
REDUCED PRICE! 1995 eagle talon w/ 6 bolt swap and light mods
i have a 1995 eagle talon with a six bolt swap. the engine is a 1992 and has aproximetly 137k on it. i bought it almost a year ago and when i bought it the kid didnt tell me that the tranny was on its death bed and it went out on me only three days later. so it wasnt driven for six months and sat in my garage while i searched for another trans. i finally found one and got it in about a month ago and am looking to sell it. along with the trans it has a few other things as well.
The Good:
Spectra Air filter and hard pipping
16G turbo with no shaft play
Powder coated valve cover (blue)
650cc injectors
Upgraded spark plug wires
New Throttle Positioning Sensor
New fuel pressure regulator
Full JDM exhaust
Fidenza Lightwheight flywheel
New dynapex clutch kit and it was broken in the right way
New Walbro 255 high pressure fuel pump
low mile transmission, about 73k on it
The Bad:
Speedometer does not work and hasnt worked since before i had the car, but it never bothered me so i didnt really look into it.
Odometer does not work.
Has some rust that has eaten through one side of the strut tower but could be fixed with a little welding.
Does not have a radio, but i have the harness hooked up so all you would need is the deck.
Has a few minor dings her and there but over all the car is in very nice condition.
I am asking 2500 for it obo, need money for school so its priced to sell. my number is 763-350-2854 call or text anytime, my name is shayne. THANKS!!!
ID:	9392   Click image for larger version
ID:	9391   Click image for larger version
ID:	9389   Click image for larger version
ID:	9393   Click image for larger version
ID:	9395   Click image for larger version
ID:	9396   Click image for larger version
shayne92 is offline   Reply With Quote
Old 11-03-2009   #2
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: 1995 eagle talon w/ 6 bolt swap and light mods
ha! I looked at this car. I test drove it the night before you bought it. I told the kid that either the clutch was almost out, or the tranny was done. It was barely driveable, how did you not notice that??
Anyway, this seems like a pretty good deal! gluck with sale.
Style's automotive engineer
Old 11-03-2009   #3
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
AWD i assume?
Amsoil Dealer
Old 11-03-2009   #4
shayne92
Yes it's AWD.
Old 11-06-2009   #5
The odometer does not work because the speedo doesnt work. On the back of the trans there is a plug that will stick up, it goes through the rear tranny mount, make sure that is plugged into the electrical and that it is in the actual transmission. That is likely the cause.
Old 02-12-2010   #6
ThEwAy2b
ThEwAy2b's Avatar
Drives: 95 TSi AWD
Where's the electical route to?
Winners make the rules!
Losers live by them!
ThEwAy2b is offline   Reply With Quote
Old 02-12-2010   #7
There is a plug on the sensor on the back side of the transmission. It wires into the main harness, then to the ECU.
Old 02-13-2010   #8
ThEwAy2b
ThEwAy2b's Avatar
Drives: 95 TSi AWD
Okay thanks, because mine flickers up and down with rpm or boost, inbetween at times of 50-140mph.
Then just sits at 0 driving at constant speed.
Hopefully it's just a short or something, because I dont want to spend 80 dollars for a new sensor. Plus you dont even get the plastic gear with the new sensor.
Old 11-06-2009   #9
did you get the car from a kid named kyle
Old 11-07-2009   #10
shayne92
ya i did get it from kyle, and i checked the plug on the tranny but the speedo didnt work with the first transmission either. I think its a wiring harness issue unfortunately.
Old 02-08-2010   #11
PLOW14
PLOW14's Avatar
Drives: Grand Prix
Hey man you figure anything out with the car yet??
PLOW14 is offline   Reply With Quote
Old 02-08-2010   #12
TurboDomestics
TurboDomestics's Avatar
the OP hasnt been on the site since November. I would try calling him if your interested.
4G63 0, Charlie 3
Old 02-23-2010   #13
Thread cleaned, this is not the tech section, move that talk elsewhere!
Old 03-11-2010   #14
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Do you still have this? IF so, have any pics of the tower?
Old 03-11-2010   #15
Jungy
Jungy's Avatar
Drives: 10' Sierra Denali & 99' beatervette
I'd say if your interested call the phone number in the original for sale post considering they haven't logged in since November.
Jungy is offline   Reply With Quote
Old 03-16-2010   #16
plow420
plow420's Avatar
Drives: 96 eclipse gsx
Car is SOLD i bought it and am currently fixing it. Car has MANY problems. including a hacked wire harness and blown hg. and turbo has the most shaft play of any turbo i have ever seen. Be happy you did not buy this
plow420 is offline   Reply With Quote
Old 03-16-2010   #17
s1ngletracker
Drives: A BMW
oof, glad to hear that you're up to the challenge though. Good luck! This thing would be a sweet car if it was running right.
Old 03-22-2010   #18
plow420
plow420's Avatar
car is mostly fixed now. new factory head gasket and properly set up ignition cuz it is a 95-96. Fixed all wiring problems and they are all soldered. Make offer...
Old 03-22-2010   #19
Your selling the car now?
Old 03-22-2010   #20
plow420
plow420's Avatar
yes i already have a 96gsx and needs a transmission rebuild now and i want a e85 tune so need money for that. The car runs good, there is a fuel leak but i'm going to fix that soon.
Tags
awd, eagle, eclipse, talon
