Old 05-10-2010   #1
Chrome moly crossmember :)
Just purchased this bad boy
The OEM crossmember, and the 2 beams that go backwards will be gone, and this in it's place. Should clear up a lot of space under there because my downpipe is already vibrating against the stock piece. Since the beams going back will be gone, he metioned it may affect cornering stability slightly, but I don't mind as I'm not too brave when it comes to cornering anyway, and I've built this car more for straight line speed.
This is a pic from the guy who made it, it should be shipping out sometime this week. Will probably powder coat it black, and then throw it in
Old 05-10-2010   #2
Re: Chrome moly crossmember :)
I too was thinking about this, as john would make me one..but I'm not sure I'd wanna do away with the two bars leading back. I'd think that's some structural support you'd be missing..
Old 05-10-2010   #3
yum. Weight reduction time, eh?
Old 05-10-2010   #4
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Speaking of weight, you have a scale near by you can weigh the two?
I'd want something to replace the stock cross members if it were me, but I'm into corners way more than straightline. Even in a straight line I'd want something in it's place though....
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 05-10-2010   #5
Thats pretty cool, I'd pick one up too if I had a 1g. Can't imagine it being any worse than me taking out my front sway bar cornering wise, and like you I built my car for straights and it doesn't bother me in the slightest!
I wanna see this thing hitting mid/low tens this year!
Old 05-10-2010   #6
I have been running with only 1 of those front/back braces for the past 4 years. But yeah I actually thought about it for a couple months before finally deciding to get it, so trust me I thought about it long and hard.
One of my biggest concerns was that I'll now have a solid front mount, so I'm concerned about added vibration. But I'm already running Prothane inserts, so hopefully it's not much worse than that. If it is, I may look at getting someone to modify it someday to accept the prothane inserts.
My main goal with it though was to lose some weight, and free up some space under there. So it'll do well at that I think.
Old 05-10-2010   #7
I have made a few of these. I would say weight savings are around 10-15 lbs if you retained the lower front/rear braces. The ones I made had flat flanges that the stock front to back pieces would bolt up to. The part looks nice and will free up some room for sure.
Old 05-11-2010   #8
damn. If I knew I would have had you make me one rather than this guy. Oh well, this looks like it's a decently built piece, and his welds look really nice although I have no clue when it comes to inspecting welds haha.
Old 05-10-2010   #9
was that from that guy on tuners?
Old 05-11-2010   #10
I got it off Paul Volk over on the Link forums. He may have them up on Tuners as well, but not sure as I don't spend a lot of time on those forums.
He said that it should be about 20lbs wieght loss since all 3 braces are no longer used.
Old 05-11-2010   #11
Constant_Project21
Constant_Project21's Avatar
Drives: E36
He sells them on tuners as well, for those of you not on link forums.
Old 06-15-2010   #12
I took lots of pics. It is a pretty easy install, but I'll be making a little How To article just for the fun of it anyway.
Old 06-15-2010   #13
Looks nice, will have to check out closer.
Old 06-15-2010   #14
Looks nice man, but I can't believe you guys delete the front-to-rear crossmembers, those stiffen up the engine bay quite a bit! Whatever works though I guess, def shaved off some weight there.
Old 06-15-2010   #15
Oh yeah, well I can't believe you have a dual exhaust on a 4-banger ya ricer.
Out with the old (on the right) and in with the new (on the left). Wish I had a scale I could weight all the old crap to see how much weight savings there was.
I'm also surprised nobody has mentioned my awesome O2 sensor, haha.
Old 06-15-2010   #16
WOW dude, I have that same one on my car. LOL (really... i do)
Old 06-15-2010   #17
How much are they?
Old 06-15-2010   #18
How much are they?
Around $165.
Old 06-15-2010   #19
I want one.
Old 06-15-2010   #20
Looks like it would make one less spot for coolant to puddle when draining the radiator, looks good man!
