Old 08-02-2010   #1
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
FS: All my Mitsu/ 3S stuff
For Sale: all my 3S stuff.
Built 6G72 short block: Pauter rods, Wisco pistons .060 over, stock forged crank, machined 4 bolt block, balanced assembly, ready to assemble. $2000 as is, $2500 assembled
Billet oil pump gears. Made by Boostaddict $400 – new never used.
http://www.3si.org/forum/f4/bfg-s-badas ... uy-439745/
Stock 5 speed 25 spline trans. Needs a rebuild and the mid case replaced. I have a replacement mid case that is included. $500
5 speed 25 spline T-case with Quadco input spool and EK2 t-case brace. $500
5 speed 25 spline T-case, input splines ok but not new. $150
CUSTOM 5 speed 25 spline trans and 6 speed t-case. These two are a matched pair, will not separate.
Custom you ask? It's been modified to be the shortest gearing possible in a 3S. It has been modified to allow a 6 speed t-case bolt to the 5 speed trans. After that it uses a JDM 6 speed front ring and pinion and needs the 5 speed rear diff to match it. The net result is the shortest gears possible for a 3S. Why would you want short gears? Mostly for autocrossing. If you are interested and want more details, here's a link: This trans also has a Quadco output shaft and a Kormex front differential. Unfortunately it needs the ½ hub and slider replaced along with 2nd gear and the syncro too. Shifts fine otherwise. $1500 obo
AEM EMS with 5 bar map and GM AIT. Tentatively sold
880cc injectors $200
13T's, non-robbeck, WG mounts are kind of iffy. Sold
Stock 3.0L with 130K on it. New oil pump, water pump, t-belt and pulleys, 3G HLA's(lifters) and valve stem seals 10K ago. Great oil pressure. Sale Pending
NA VICS manifold and a custom built box that allows the AEM EMS to control it. $100
IC setup with 12x24x4.5” PTE core, custom endtanks, and custom short route IC pipes. 2” hot side 2.5” cold side. It will probably not work on a car with A/C and you will need to redo the power steering cooler. Solid motor mounts required as well (included). Will not work with stock fans. Tial
50mm BOV included. $1300
Walbro 255 Sold
SCE Oil pan – 4 bolt - $Sold
Stock TT axles. $50 each, multiple rear sets, one front set.
Window regulators- re-enforced, won't break again. $100 per side.
Fuel Lab AFPR, -6 ports PN: 51502-1 Black Brand new never used! $120
Old 08-18-2010   #2
MustGoFaster
Re: FS: All my Mitsu/ 3S stuff
Sold parts updated.
