View Poll Results: Should The Ends Of An Intake Be Bead Rolled?
Yes 6 50.00%
No 2 16.67%
Just The BOV Tube 4 33.33%
Voters: 12. You may not vote on this poll
Closed Thread
Old 08-12-2010   #1
blageo23
AWD4G64
blageo23's Avatar
Bead Roll Ends On Intake
I would like to hear your guys feedback on this. Dont just vote let me know why you think one way or another. This poll is based off of our Evo 10 intake that is still being finalized.
1998 Spyder AWD
567hp
490tq
blageo23 is offline
Old 08-12-2010   #2
Re: Bead Roll Ends On Intake
You know my reasons. I would think with no pressure inside, or anything really forcing the intake pipe off, why need them? It's only job is to get air into the turbo..that's it. I've never had beads on any of my intakes in the past.
Swifty1638 is offline
Old 08-12-2010   #3
Yes. My X filter was slipping off until I sanded it a bit to rough it up, my wife's WRX filter was slipping off her SPT intake pipe, and my dad's GTO filter was slipping off his K&N intake pipe. The WRX and GTO filters seemed very secure and tight during installation, but after a few thousand miles they slipped off from the vibrations. I also found that over-tightening the filter clamp to prevent slippage was causing them to be squeezed off. These are all things that a small bead could have prevented.
To me this seems like one of those "why not?" type of things. Best case is saves a filter from slipping off; worst case it's still an extra attention to detail you have over the competition.
Kracka is offline
Old 08-12-2010   #4
mlomker
*Resting In Peace*
mlomker's Avatar
This intake was 'inspired' by the AMS 3" intake. They do roll the BOV pipe since it's going to be hit by blasts of air that needs to be recirc'ed and that blast will be in the direction that could blow the hose off.
I'm in the process of switching to t-bolts so I'd imagine it'll stay on but in general I'd recommend it.
I don't really see the need for it on the air filter pipe. If there was a rush of air inward then it'd just seat it better, not take it off.
mlomker is offline
Old 08-12-2010   #5
Yes. More security. If you have a short 10" long intake with a 5" opening (swifty), you have more surface area. If you have a 25" long pipe with no supports on it thats 3" or 3.5" diameter, there's less surface area on the turbo inlet to hang on.
Let's look at some intakes by some of the other major manufacturers out there:
Buschur:
ETS:
AFI:
AGP:
Greddy:
HKS:
All have beads. Get any oil in there (blown turbo or a stock-style PCV system) and the thing will slip off pretty easily w/o beads...especially if you account for installing and then running for 20k miles w/o touching it (tough for some people I know!), the vibrations alone would be enough reason for me. IDK why there is even a question about not putting them on, it seems silly not to, Rolling a bead is cheap/easy, especially on 3.5" pipe w/o big angles on the end.
scheides is offline
Old 08-12-2010   #6
Rolled ends make the product appear higher quality. Think about it. Yes, it is just an intake tube. But do you want to cut corners (it's more preference in this case) and make a "shitty part" or make something that is actually better than the competion? Give people a reason to keep coming back, to tell their friends, to ask for more stuff to be made. And if it means raising the price a tiny bit, it still may be worthwhile.
sleepydsm is offline
Old 08-12-2010   #7
That's true, the cheap ass air filter pipes I've seen didn't have beads.
Goat Blower is offline
Old 08-12-2010   #8
I voted just BOV, but if someone could change it to both. ^Agreed.
My FP intake had beads on all ends too, but I've used homemade pipes on other cars and no problems.
The intake actually makes a vacuum, sucking the intake onto the pipe.
I am really surprised a vendor is making a thread about this.
turbotalon1g is offline
Old 08-12-2010   #9
blageo23
AWD4G64
blageo23's Avatar
Only reason I made this is to see what the consumer would like. I see it both ways but if the consumer will sleep better at night knowing there is a bead roll on his intake then by all means we will bead roll it.
1998 Spyder AWD
567hp
490tq
blageo23 is offline
Old 08-12-2010   #10
Mwolf83
Drives: 91 Eagle Talon AWD, 02 WRX, 97 Civic Hatch
Bead roll it because....why not? Less things to have to worry about the better, especially in the DSM community.
Mwolf83 is offline
Old 08-12-2010   #11
Needs to be bead rolled for doing boozt leak tests.
Shane@DBPerformance is offline
Old 08-12-2010   #12
^Bingo.
Thanks to primo for getting our thoughts I will sleep better. Not too many out there want to go that far to please us.
Hmmm, wonder what else they will do?
lol
Old 08-12-2010   #13
mlomker
*Resting In Peace*
mlomker's Avatar
Looks like AMS is off on their own there. I'm for anything that doesn't add another 2-4 weeks to getting my intake. My build is already epic.
mlomker is offline
Old 08-12-2010   #14
I say no to both. I've never had an intake pipe with a lip on my 2G or 1G.
Halon is offline
Old 08-12-2010   #15
311evo
311evo's Avatar
imo not necessary, but doesn't hurt having everything a bit more sturdy.
311evo is offline
Old 08-12-2010   #16
blageo23
AWD4G64
blageo23's Avatar
^Bingo.
lol
Reach arounds are extra! LOL
I like to see people thoughts and as halon said I have never had an intake with bead rolled ends. Shane makes a good point about the boost leak test.
1998 Spyder AWD
567hp
490tq
blageo23 is offline
Old 08-12-2010   #17
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Honestly, the first thing I noticed when I picked it up was...no bead rolls? But I didn't think it was absolutely necessary, but people make some good points.
Murlo26 is offline
Old 08-12-2010   #18
Boost leak tests, vibration, misaligned fitment (we've all been there)... The list goes on. There's no reason not to have a bead rolled on intake pipes.
Matt D. is offline
Old 08-13-2010   #19
mx3twinturbo
mx3twinturbo's Avatar
Drives: StarQuests>>>>>>
final versions will be bead rolled on all ends,
Decision made, :-)
Thanks for all the input we want to know what are customers want! so we can deliver the highest quality part to YOUR specs.
Mods feel free to close this thread,
Jesse-
Primo Performance
651-204-7040
1987 Conquest- 2.1 project started...
1986 Dodge D-50- S.C. truck 2.6 turbo swap started
1992 Mazda Mx-3- Rear mount twins in progress
1989 Suburban- Project for too Long!!!
"Just Remember, I HATE Drama"
mx3twinturbo is offline
Closed Thread
