Old 06-10-2010   #1
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
FS DSM parts stock and aftermarket
Here they are. PM me if interested in anything with an offer.
1g
Idle air control valve
91+ shifter assembly
talon passenger tail light
motor mount tensioner bracket driver side
timing pulleys
main seal cover
dip stick
crank timing gear and plate
center console carpet sides dark gray
A pillar driver and passenger dark gray
non turbo oil pan 6 bolt
stock rubber intercooler
stock intercooler hoses
1990 4 spyder center differential
starter
gauge cluster 112k miles
fuel rail
fuel pressure regulator
radio trim black
cup holder insert
flip up head light trim
flip up headlight motor
flip up headlight assembly driver side
non turbo throttle body with sensors
green top CAS with pigtail
thermostat housing with sensors
2g
main seal cover
stock exhaust manifold
ported stock exhaust manifold
intercooler hard plastic pipe that bov mounts to
exhaust manifold heat shield stock
exhaust manifold heat shield bowdercoated black
speed sensor
knock sensor
top transmission bracket manual
tranny side motor mount
front tranny motor mount
thermostat housing with sensors that are new
throttle body
stock fuel pump
fuel rail
grey and black center vent with switches
cruse and mirror switches and trim in gray
clutch fork boot
T25 stock turbo in good shape
stock 02 o2 housing
AWD fuel sending unit
shifter assembly
driver 2 piston caliper and both driver and passenger brackets
driver and passenger front knuckles with wheel bearings but 1 broke stud
shift fork
stock BOV return pipe
Lower 2g 7 bolt timing cover
battery tray
mdp/map sensor
plug wires
driver motor mount (needs insert)
gray trunk inner cover
coil
2g fwd fuel sending unit
throttle position sensor
rear tranny motor mount
front pasenger awd axle (one non abs and one abs)
starter
2gB projector black housing headlights with bulbs
intake manifold
coil
transistor
AWD gas tank
gauge cluster trim
top timing belt cover
rebuilt 2g head with a few bent valves
driver air bag gray talon
passenger air bag gray
shifter shift cables
main drive shaft
stock fans
inner passenger fender plastic shroud
upper radiator hose
lower radiator hose
driver front wheel well plastic
gray center console and plastic sides
gray door panels
radiator
manual AWD tranny for parts
MISC.
Walbro 255 hp pump almost new
tial 4 bolt wastegate 41-44mm
ebay 44mm wastegate with tial dual springs
3 inch intake with AEM filter
Hyundai valve cover with plug wire cover
2g stock valve cover
powdercoated red perfect valve cover
2.4 4g64 6 bolt bare block (no rods, pistons, or crank but has all main caps)
small 16g (ran a few years back well but sold as parts turbo)
7 bolt normal ARP headstuds
intrepid coils and pigtails
8-10" -4 AN SS line
-10 AN turbo bolt on oil drain adapter
-4 turbo oil feed adapter off of oil filter housing
Amsoil Dealer
Old 06-10-2010   #2
Twitch
Twitch's Avatar
Drives: 2005 GTO, 2006 Duramax, 92 turbo civic, 85 Grand National
Send a message via AIM to Twitch
Re: FS DSM parts stock and aftermarket
What do you want for the red powdercoated vc and could you find a 6 bolt lower TB cover?
Twitch is offline   Reply With Quote
Old 06-10-2010   #3
95talonracer
Finally Tuned...
Drives: Spyder GSX
PM sent
Amsoil Dealer
Old 06-20-2010   #5
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
how much for the T25?
Style's automotive engineer
Old 06-20-2010   #6
lpomega
lpomega's Avatar
Drives: 97 GSX
How much for 2g radiator?
lpomega is offline   Reply With Quote
Old 06-20-2010   #7
95talonracer
Finally Tuned...
Drives: Spyder GSX
PM's sent.
Amsoil Dealer
Old 06-20-2010   #8
Spikesoftail
Spikesoftail's Avatar
Drives: 96 Talon Tsi AWD Auto
Any chance you've got a nice 2g FMIC for sale? Will the Intrepid Coils work on a 2G?
Spikesoftail is offline   Reply With Quote
Old 06-29-2010   #9
mitsukid124
mitsukid124's Avatar
Drives: 97 eclipse gst
how much for the radiator? and any pics?
mitsukid124 is offline   Reply With Quote
Old 08-26-2010   #10
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
1g or 2g walbro?
Originally Posted by 311evo
Old 09-19-2010   #11
s1ngletracker
Drives: A BMW
remind me again how much you want for the T25?
Old 09-19-2010   #12
95talonracer
Finally Tuned...
Drives: Spyder GSX
Originally Posted by 19TsiAwd90 View Post
1g or 2g walbro?
UMMM same pump just different install and it is sold.
$100 and its yours. no shaft play.
Amsoil Dealer
Old 09-28-2010   #13
19TsiAwd90
19TsiAwd90's Avatar
Old 10-03-2010   #14
19TsiAwd90
19TsiAwd90's Avatar
still got that 3in intake, and does it come with coupler?
Old 10-04-2010   #15
throwedgsx
throwedgsx's Avatar
Drives: 09 Mustang GT, 98 Lumirod
How much do you want for the 2.4 bare block??
'95 TSi AWD
throwedgsx is offline   Reply With Quote
Old 10-05-2010   #16
Gravy
Who's this guy?
Does the 1g IAC work and how much?
Old 10-05-2010   #17
Spikesoftail
Any chance you have some rear struts for a 2g
"Call amberlamps"
Old 03-05-2011   #18
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Hey man I need some motor mounts for a 2g manual. Give me a call/text me at 763-464-4482
Old 03-05-2011   #19
19TsiAwd90
19TsiAwd90's Avatar
got the shine through lens that go infront of the pup up lights?
Old 03-05-2011   #20
95talonracer
Finally Tuned...
Drives: Spyder GSX
yep pm me
Amsoil Dealer
