Old 10-21-2010   #1
Who does professional eprom socketing locallY?
Does anyone know anywhere that will put in a socket for a eprom chip locally?
Thanks
Aaron
Old 10-21-2010   #2
Re: Who does professional eprom socketing locallY?
I know Shane has a guy that does it, give him a call.
Old 10-21-2010   #3
twack
It was a auto get over it
twack's Avatar
I had Steve from Wisconsin do it, he will give you a whole diagnostic check on your ecu as well, so more then worth the money
Old 10-21-2010   #4
^Any info on that guy?
Googling steve from WI isn't too helpful
Old 10-21-2010   #5
blackrosenova400
blackrosenova400's Avatar
I can do it for you if you have the socket. In fact I may have one around. LMK!
20g Mafia
Old 10-21-2010   #6
There's different kinds of sockets as well. Make sure whomever does it uses the correct socket. I don't remember which design is the correct version, but the "wrong" ones don't hold the eprom chip in there very well. I had an issue with that once and the DSMLINK guys changed out my crappy socket for the right one.
Just something to keep in mind...
Old 10-21-2010   #7
twack
twack's Avatar
http://forum.widsm.org/member.php?17-steve
steve
Old 10-22-2010   #9
OMGZ!!!!!!!!
it looks gorgeous, looks like we know where to take the $$$ to get some quality soldering done. I hope everything falls in line now.
Old 10-22-2010   #10
blackawdtsi
Drives: 2G DSM
I had mine done by Rick Shindley way back in the day haha.
Old 10-22-2010   #11
blackrosenova400
Desoldering was the worst part. The chip was glued in there. I kept thiking I missed some solder because the chip wouldint budge.
Then I inserted the new socket and it wouldnt seat all the way as there was a small resistor in the way, so I made a little notch in the socket to clear it.
Btw how much was the ZIF socket?
20g Mafia
Old 10-22-2010   #12
$10 from DB and $10 for the reprogrammable chip also from DB.
Thank you to both you and shane.
Old 10-24-2010   #14
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
Looks like we know who solders now. What program are you running turbotalon? DSMlink?
Old 10-24-2010   #15
Yes I run DSMlink.
Also Blkrosenova, I have a customer lined up for you.
