Old 11-10-2010   #1
vassil
vassil's Avatar
1G Rear wheel drive 25.1e tube chassis DSM -- $CHEAP
1992 GSX RWD 25.1e tube chassis -- $4000
I started building this car with lots of hopes and aspirations. Over time I have lost interest and have moved to other projects. The tube chassis fits perfectly inside a 1G DSM shell. The chassis itself is made from 4130 Chromoly and fully tig welded. It weighs around 275 lbs. When complete the Eclipse would weigh just a hair over 2000lbs. The 4-link is a S&W racecars pro series and is 24" wide with strage coilovers. The car is setup for a 4G63 and a powerglide. The rear has Weld Alumastar 15x14 with MT ET Drags. The car comes with Buschur Racing 4G63 to GM Tranny adapter and an SFI flexplate. Steering, seat & pedals are complete. You need to finish up the front suspension, tin the car, get a fabbed rear housing, diff and install brakes. This is a massive project, but it is something very unique that hasn't been done before. I am selling everything as a package for $4000. It is a complete steal, considering a welded chassis alone will run you about 5000-6000, not to mention all the parts included. The raw materials and parts are worth about 7000. The labor cost will be probably exceed $4000. Below you can find a full list of the parts included and their price as well as some pictures.
For a gallery of pics, you can visit http://www.vasso.net/tubecar.html
  • SW Racecars Chromoly Chassis Kit --- $1999
  • SW Rcecars Pro Series Welded 24" Chromoly 4-Link Rear Frame --- $2399
    • 4-Link Rod End package
    • Fully Welded Track Locator
    • Strange double adjustable coilovers
    • Hypercoil 150lb springs 2 1/2 x 12 (blue)
  • 35-042 Willwood Rack and pinion --- $321
  • Pito Tie Rod end kit, S&W Steering Column Kit --- $221
  • Strange Dual Master Brake Cylinder --- $104
  • Grant D-Shape Steering wheel --- $97
  • Quartermax 360 driveshaft loop --- $118
  • Quartermax 180 driveshaft loop --- $36
  • Quartermax Parachute kit --- $83.95
  • Stroud Window Net --- $80
  • RCI 4 gal fuel cell --- $119
  • Jegs Line Lock Selenoid kit --- $39
  • Wilwood proportioning valve --- $41.99
  • Wilwood residual valves --- $35.99
  • Burschur Racing Flexplate --- $275
  • Burschur Racing 4G63 Adapter Plate GM Transmissin --- $350
  • Weld Alumastar 15x14 (5x4.5 Circle) 5" backspace wheels --- $954
  • Used MT 32x14.5x15 Tires with tubes --- $100
The total price for the parts & materials alone is: $7281
Here are some pictures of the car/project:
Manual 859.8WHP / 642 ft/lbs
10.23@152
Automatic 728WHP / 517 ft/lb
9.85@143
1G DSM Crossmembers
BulFab
