Old 10-23-2014   #1
C89ZX7R
C89ZX7R's Avatar
Drives: 87 and 89 Chrysler Conquest
87 Mitsubishi Starion 4G64.3 Swap Time
STILL BUYING ENGINE PARTS.
* Build List "Parts I Currently Have"
6-Bolt 4G64 Wideblock
6-Bolt 4G64 Crankshaft
6-Bolt 4G63 Dohc Cylinder Head
6-Bolt Pauter 156mm X-Beam Rods
Jay Racing Billet Main Caps
Kiggly Main Girdle Brace
Kiggly Racing Beehive Valve Springs
Ferrea Stainless Steel Intake & Exhaust Valves
Ferrea Intake & Exhaust Valve Guides
GSC Power Blue Intake & Exhaust Valve Stem Seals
JDM Evo 8 Intake Manifold
Holset HE351CW Turbocharger
Arp Head Studs
Arp Main Studs
Jay Racing Front Water Outlet
Jay Racing Blank Coil Plate
Jay Racing GM Alternator Relocation Bracket
Shaved Dual -AN'd Valve Cover
Magnus Fuel Rail
*Parts Being Used From Previous Motor
Aem EMS-4
Aem Smart Coils
Aem FPR
Aem Boost Solenoid
KDM Mpi Intercooler Piping
KDM 4" Intercooler
KDM Radiator
KDM 3" Exhaust
Greddy Type-R Bov
Motorad High Flow Thermostat
Fenderwell Cold Air Intake
Current Installed Mod List
Drivetrain Modifications:
Competition Stage 4 - 6 Puck Sprung Clutch
Short Shifter
Poly Transmission Mount
GNT Torque Tube Bushings
GNT Differential Mounts
Suspension Modifications:
S&M Front Tri-Point Strut Bar
S&M Rear Strut Bar
Cusco Front Adjustable Camber Plates
Eibach Pro Lowering Springs
Front Suspension Tech Larger Sway Bar
Rear Suspension Tech Larger Sway Bar
Brake/Wheel Modifications:
Abs Bypass Line
Refinished & Polished Rims
Datsun Z Brake Reservoir's
Slotted & Drilled Rotors
Interior Modifications:
Tan and Black Leather Interior
Autometer Carbon Fiber Boost Gauge
Innovate Digital Wideband
35% Madico Tint
Push Button 2 Step Shifter Knob
Console Hi/Lo Boost Switch
Aem Usb Ecu Port
Electrical Modifications:
GM 110 Amp Alternator
Red Top Optima Battery
Welders Wire Battery Relocation
Custom Relayed Cooling Fan Harness
Putco H4 Relayed Headlight Harness
Silver Star Zxe H3 55 Watt Fog Bulbs
L.E.D. Modifications:
X2 Truck-Lite 5x7 Led Headlights - 2600 Lumens
X1 White Ashtray Led - 10 Lumens
X2 Amber Front Side Marker Led - 100 Lumens
X6 Red Tail Light Can Bus Led - 420 Lumens
X2 Amber Front Signal Can Bus Led - 100 Lumens
X2 White License Plate Led - 150 lumens
X2 White Reverse Led - 400 Lumens
X2 White Front Running Markers - 260 Lumens
X1 Third Brake Led - 62 Lumens
X3 Door & Dome Led - 80 Lumens
X1 CF12ANL-01 Led Flasher Relay
Replaced Oem Parts:
New Wheel Bearings
New Control Arm Bushings
New Strut Rod Bushings
New Ball Joints
New Tie Rods
New Tie Rod Adjuster
New A/C O-Rings
Other Modifications:
83 Metal Scooped Hood
Anti-Roll Over Valve
Rotella T6
I have two wideblocks. One is a G64B and other is the 4G64. Using the G64B for the mock up build while I order and build the 4G64. Mock up pics below.
P.S. CAR IS ALREADY WIRED FOR SPEED DENSITY USING A 4G63 SENSOR, WAS A DAILY DRIVER FOR THE PAST 12K MILES...
[B]
Motor Is Tight, Sounds Unbelievably Badass, Intimidates Slow Hondas Instantly
C89ZX7R is offline   Reply With Quote
Old 10-23-2014   #2
Re: 87 Mitsubishi Starion 4G64.3 Swap Time
Awesome, I still have a soft spot for Starions. My first turbo car was a '87 Starion.
Old 10-23-2014   #3
Very nice.
ALways love these cars.
Old 10-23-2014   #4
Very nice.
Old 02-05-2015   #5
C89ZX7R
C89ZX7R's Avatar
Old 02-05-2015   #6
It looks so tiny!
Old 02-05-2015   #7
C89ZX7R
C89ZX7R's Avatar
It looks so tiny!
Yeap
Old 02-05-2015   #8
Holy shit.
Old 02-05-2015   #9
C89ZX7R
C89ZX7R's Avatar
Valve Springs are Kiggly Beehives if anyone wanted to know. Bottom end parts will be ordered shortly. Looking at the 2.4 Long Rod Ratio "156mm rods, 1.130 pin height pistons"
Old 02-06-2015   #10
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Nice, looks good! I always wanted a starion or a conquest.
p.s. nice hoover, i have the exact same one lol
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 02-06-2015   #11
Hmmm, I didn't know there was that much of a difference in block size. I suppose it makes sense having the bores that much bigger to accomodate 2.6 liters. Leaves some room in front for a bigger radiator.
Old 02-10-2015   #12
C89ZX7R
C89ZX7R's Avatar
Stock G54B 2.6L Pistons are 91.1mm
Did some coil mock ups the other day, think Im going to mount them like this.
Old 02-10-2015   #13
C89ZX7R
C89ZX7R's Avatar
Picked up the turbo for the swap, cant wait. "HE351".... Also just picked up the crankshaft from the machine shop, which said its in great shape. Thats a relief cause factory 6-bolt 64 cranks are really hard to find.
Old 02-10-2015   #14
C89ZX7R
C89ZX7R's Avatar
Just ordered HE351 to 3" exhaust adapter from Pure Diesel Power.
Old 02-10-2015   #15
typeRA
Drives: 22b bro
are the starion trans pretty tough?
Old 02-10-2015   #16
C89ZX7R
C89ZX7R's Avatar
Up to 400 yes. After that is best to use an adapter with a supra trans or the B2600 bellhousing on a rx7 trans.
Old 02-10-2015   #17
C89ZX7R
C89ZX7R's Avatar
1st post edited and updated
Old 02-19-2015   #18
C89ZX7R
C89ZX7R's Avatar
Mail call. HE351 to 3" Reducer just came in the mail.
Old 04-15-2015   #19
C89ZX7R
C89ZX7R's Avatar
Just paid for 156mm 6-Bolt Pauter X-Beam Rods.
Old 05-09-2015   #20
C89ZX7R
C89ZX7R's Avatar
Billet Main Caps, Arm Main Studs and Kiggly Girdle has been ordered.
http://www.jayracing.com/billet-main...g63-p-318.html
