Old 05-20-2004   #1
DSM97RS
Send a message via AIM to DSM97RS
http://www.angelfire.com/mn2/arcadecontrols/coolant5
the part of the radiator im point to in the pic is leaking coolant through a pin sized hole. It looks like the metal that runs on the bottom of the radiator has broken off causing the leak. Is this fixable? what would it require?
DSM97RS is offline   Reply With Quote
Old 05-20-2004   #2
b00stingsx
Send a message via AIM to b00stingsx
At checker auto, they sell a radiator repair kit. In it is a fiberglass patch, some sand paper, a sealer and catylist and a brush. You sand around the leak/hole, then cut a piece of fiberglass patch to size, then mix the sealer and the catylist together, brush it on, and let it harden. it worked good for me.
Also, i think there is a additive you can put in your system that will fix leaks. Not sure of how well it works though.
b00stingsx is offline   Reply With Quote
Old 05-20-2004   #3
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Ya buy a new one. around $150.00 and it should last like a hundres thousand miles. :goodluck:
Take her to the limit!
Old 05-20-2004   #4
DSM97RS
before i buy a new radiator, would it be possable to solder the leak shut since its very small or no? if i can fix it for free rather than spend 150$ that would be great.
Old 05-21-2004   #5
fmicmatt
Guest
Tournaments Won: 6
Posts: n/a
Call a radiator shop! The braze or solder stuff like that all the time.
Or save the Ass Ache and get a new/used one.
Old 05-21-2004   #6
Enes
Enes's Avatar
too bad i sold a good one last night
