Old 05-20-2004   #1
Emcee gsxtc
Emcee gsxtc's Avatar
My buddy's 1990 Eagle Talon TSI AWD stock except polished head.
Symptoms:
It boost 3psi at idle.
When you rev it up (sitting parked) it boosts with rpms.
Slow revving.
Any ideas, I dont want to suggest any of my thoughts to influence others thoughts.
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 05-20-2004   #2
Well, it is not creating boost at idle. There is something wrong in the electrical system. It is probably sluggish because it is very rich from thinking so much air is going into the system. I would start out by swapping MAS's, then check the ECU for leaky caps.
Old 05-20-2004   #3
1Fst14B
Send a message via AIM to 1Fst14B
Symptoms:
Slow revving.
are you using a real boost gauge? or the stock one...
1Fst14B is offline   Reply With Quote
Old 05-21-2004   #4
Emcee gsxtc
im pretty sure he was using stock boost guage :naughty: we will try swapping mas and ecu, Thanks as always.
