Old 03-22-2010   #1
BogusSVO
BogusSVO's Avatar
Drives: 1985 Ford Thunderbird Turbo Coupe
Oil Port#1 for 4G63T
4G63T Head Oil Port Modification
This is a simple and effective mod done to the oil port from block to head.
I have found out a restriction can occur when excessive milling of the head has been done.
Resulting in low/poor oil flow through the cylinder head that can cause lifter tic, cam tower gaulding, and in some cases on turbo engines that feed the turbo oil from a port on the head, to cause the turbo to fail.
Appox mod time with head of engine is 2 mins.
Stock oil port….
Take a die grinder with an aluminum burr and grind and chamfer the oil port, while staying inside the gasket-sealing ring. (I find a ¾ base tree burr works best)
So the end result looks like this.
I prefer this to be done before the head is resurfaced.
I hope you find this useful.
BogusSVO is offline   Reply With Quote
Old 03-22-2010   #2
Re: Oil Port#1 for 4G63T
This is a cool idea and makes perfect sense! Anyone ever seen this done before?
Old 03-22-2010   #3
Is that the only port that oil enters the head from?
Seems like a great idea, anyone else ever tried this?
Wait, isn't that where the headstud goes through? Confused me now.
Old 03-22-2010   #4
BogusSVO
BogusSVO's Avatar
no one that I have talked to has... I have it up on Tuners, and CODSM along with a few other fourms.. It seems to be a "new deal"
I have not seen it on a Busher head, nor a few other high dollar DSM heads
Old 03-22-2010   #5
BogusSVO
BogusSVO's Avatar
hes that is where the oil flows from block to head, and yeas a head stud dose go thu there...
Old 03-22-2010   #6
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Hmmm, I'll be building a head soon. I'll have to take a couple minutes to do this.
Old 03-22-2010   #7
Nightjoker7
Drives: 04 Evo 8 SSL - 95 Eclipse gsx -2011 Chevy Caprice PPV
Send a message via MSN to Nightjoker7
I have heard of this being done before. seems like a really good idea
Nightjoker7 is offline   Reply With Quote
Old 03-23-2010   #8
BogusSVO
BogusSVO's Avatar
Nightjoker... where have you heard of this mod before?
Old 03-23-2010   #9
Probably one of your posts from another forum Scheides and I were reading up on some of the tech info you posted on a Cincinnati forum.
Old 03-23-2010   #10
BogusSVO
BogusSVO's Avatar
yeah, I am on a few forum boards... cincy, and DSMtuners too lol
Old 03-23-2010   #11
Nightjoker7
Ya i think i saw it on dsm tuners or somthing. Dont really remember it was awhile ago.
Old 03-23-2010   #12
This is the first I've heard of oil pressure to the head being a problem. With ten parts cars popping up every day, I can't see why anyone would mill their head more than once where this would be a problem. In fact, the high rpm drag guys are getting too much oil pressure to the HLA's making them pump up and cause problems, hence modified restrictors being sold like the one Kiggly makes. That's probably why you haven't seen this mod before. I always chamfer both oil and water ports slightly after milling, but only for cleanup purposes. Maybe this is a good thing, I'm not sure.
Old 03-23-2010   #13
FP claims a lot of stockframe Evo turbo failures (although its only FP turbos that are failing which may be due to them not using OEM Mitsu center sections) are due to not enough oil pressure from the head, I can see this helping slightly.
Old 03-23-2010   #14
BogusSVO
BogusSVO's Avatar
this is not so much about pressuer as it is flow, preusser is the amount of force needed to pass thu a clearance, flow deals with the amount
If the head has been milled, at this trough os now smaller, which should increase pressuer, but reduce flow
when this happens, lifter tick happens, and now also the turbo may be not getting enough oil ( for the guys that are set up 1g style from the side of the head.)
so when this mod is done it will restore the oil flow, and reduce oil pressure by a few psi
to help simplfy... at say 50psi, you can flow (GPH or LPH) more thu a garden hose , than you can a drinking straw at the same pressuer.
Old 03-23-2010   #15
What about negative pressure? I'm having a hard time getting enough Captain to flow through my straw right about now.
Old 07-10-2013   #16
blesi660r
blesi660r's Avatar
Ok i ahead of time apologize for bringing back the dead but I have a Q about this mod:
When doing the port on this how deap do you go, or do you not really go any deaper but just widen
the port like said and not ad any depth?
I would like to do this befor my head goes out to gosh for resurfacing.
Just couldn't stay away.
Old 07-10-2013   #17
I just made mine a nice smooth transition instead of a hard 90-degree curve. You don't need to go that deep.
Speaking of that, I didn't notice any difference doing this, I still have a slight lifter tick and my oil pressure was still really high until I ported the beejeebus out of the oil relief valve. I just did this because it seems like a good idea and I port everything for smooth flow. Me and my cabinet of flapper wheels and bits are close buddies.
Old 07-10-2013   #18
blesi660r
blesi660r's Avatar
Lol. Thanks for the info, I'll just do a smooth transition of the port.
Old 07-12-2013   #19
blesi660r
blesi660r's Avatar
Should I go a little more ?? Not sure
Old 07-12-2013   #20
Looks like you could probably go a little wider if you wanted. Towards the right in the pic. Then smooth it out some.
