Old 11-08-2016   #1
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
EvoTuna's Newest Partout, FP Turbos, Shep, Trans & Tcases, Frontline Fab, ACT, VOLK!
BLACK FRIDAY DEALS!!!! UPDATED POST!! 10% OFF ANYTHING POSTED!!
Evo 8/9 Multiple Evo Partout:
-Ad is self-explanatory, EVERYTHING IS IN GOOD-GREAT WORKING CONDITION UNLESS STATED OTHERWISE. Texting is the best way to get ahold of me, email and pms will take me longer to get to. Shipping will be done over the weekends because I work a billion hours a week, unless it’s something I can ship out sooner, then I most certainly will. I have a couple hundred photos of the rest of parts so feel free to ask for more. I can only load 42 on a sale post haha.
-I'm located in Mankato MN. If it’s not listed I more than likely don’t have it.
-Phone # 507-215-2103. Texting is preferred.
Thanks
Chris
Evo 8/9 Engine/Drivetrain/Turbos/Manifolds/Cams/Aftermarket
-FP Zero Ball Bearing with Install Kit and MAP Downpipe (EVERYTHING IS BRAND NEW) - $3100 shipped
-FP Black Ball Bearing with Install Kit and STM Downpipe (EVERYTHING IS BRAND NEW) - $3100 shipped
-Evo 9 Turbo Comes with Wastegate/Lines/ETC (Good condition) - $450 shipped
-Evo 8 9.8 Turbo Comes with Wastegate/Lines/OEM Exhaust Manifold/Megan O2 Housing - $380 shipped
-Garrett GT3582R ATP-VEVO-006 Full Kit - $2200 shipped
-Evo ACD Tcase 60xxx miles - $1300 shipped
-Evo ACD Tcase 100xxx miles - $1250 shipped
-Evo NON ACD RS (LSD) Tcase 70k miles - $1250 shipped
-Evo 9 Rear Diff (Restacked Plates) - $700 shipped
-Evo 8 Rear Diff - $600 shipped
-Front Axles - $250 shipped for a set or $125 each (3 Driver Fronts and 1 Complete Set)
-Rear Axle Set - $250 shipped
-Speed Density Intake (Brand New) - $160 shipped
-Buschur Double Pumper $450 shipped
-OEM Fuel Hanger with Wally 255 - $140 shipped
-Magnus Fuel Rail with line - $120 shipped
-PTE 1600s Injectors - $300 shipped
-DNP Coated Tubular Manifold (2k miles) - $700 shipped
-Cobb Downpipe (ACD) - $250 shipped
-3” Vband Test Pipe (Both ends) - $50 shipped
-Frontline Fab Rear Diff Cover BRAND NEW - $420 shipped
-ACD HDSS Pressure Plate (Needs new clutch disc) - $180 shipped
-ACT Streetlite Flywheel (Perfect shape! 200 miles on kit, bought new, swapped out for Exedy Twin) - $220
-ACT Lightweight Flywheel - $140 shipped
-Mishimoto Half Sized Radiator with Fan - $250 shipped
-Weldon Surge Tank Kit (Everything needed for install) - $300 shipped
-Nitrous Kit/Intake Manifold for Evo 8 - $300 shipped
-3 Good Manley Turbo Tuff Rods/Manley Pistons - $300 shipped
-3 Good Oliver Rods - $200 shipped
-Braided Clutch Line - $40 shipped
-CF Spark Plug Cover Evo 8 - $70 shipped
-Cusco Catch Can - $80 shipped
-Moroso Catch Can - $80 shipped
-Evo 8 Valve Cover 7/10 shape - $180 shipped
-Solid Front Motor Mount - $30 shipped
-Megan or similar brand Exhaust Tubular Manifold - $70 shipped
-Aftermarket 02 Housing - $30 shipped
-Evo 9 Wastegate - $80 shipped
-MAF - $50 shipped
-(2) Stock Turbo Intakes - PM for pricing and pics
Evo 8/9 OEM Engine Parts/Manifolds/Sensors/Odds and Ends ETC.
-Box of Like New Timing Components – PM Me
-Knock Sensor - $50 shipped
-(3) O2 Sensor - $30 shipped
-(2) MAP Sensors - $30 shipped
-(2) Oil Pressure Switches - $15 shipped
-(3) OEM Driveshaft in very nice shape - $100 each plus shipping
-OEM Exhaust Manifold - $50 shipped
-OEM O2 Housing with O2 Sensor - $50 shipped
-(3) OEM Intake Manifold - $75 shipped (One has EGR still and MAP Sensor)
-OEM TB - $40 shipped
-DSM BOV - $30 shipped
-OEM Fuel Pump Hanger NO PUMP. Missing a few things. - $60 shipped
-(3) OEM Starter - $90 shipped
-(2) OEM Alternator $90 shipped
-(3) Motor Mount Bracket to Block - $80 shipped
-(5) Block to Trans Shield with Starter Hole – $30 shipped
-(2) Flywheel Shields (Under block, bolts into trans) - $25 shipped
-Master Cylinder - $50 shipped
-(4) AC Delete Serpentine Belts - $20 shipped
-LIKE NEW OEM Evo 8 Water Pump (Idle time only) - $80 shipped or best offer
-(2) OEM Serpentine Belt Tensioner - $75 shipped
-(5) OEM Crank Pulley - $40 shipped
-MIVEC Oil Line - OFFER
-Evo 8/9 Rockers – PM Me
-Cam (Exhaust) Sensor Housing Evo 8 - $30 shipped
-(4) OEM Cam Gears - OFFER
-OEM Evo 8 Cams - OFFER
-(2) Oil Dipstick with Tube - $30 shipped
-(3 sets) OEM Evo 8/9 Ignition Coils - $40 shipped
-(2) OEM Fuel Rail/FPR - $40 shipped
-Fuel Pressure Regulator/Line - $20 shipped
-(2) OEM Radiator and Fan/Module Assembly - $120 plus shipping
-Radiator Fan/Module - $80 shipped
-Radiator Fan no Module - $50 shipped
-(5) OEM Upper Radiator Pipes - $20 shipped
-(9) OEM Lower Radiator Pipes - $20 shipped
-(6 sets) OEM Radiator Mounts – OFFER
-Evo 8 Coolant Hard Pipe and Thermostat/Sensors - $100 shipped
-(2) Evo 9 Coolant Hard Pipe and Thermostat/Sensors - $100 shipped
-(2) Evo 8/9 Thermostat Housings with Sensors - $40 shipped
-Evo 8 Lower Timing Cover - $40 shipped
-OEM Clutch Slave - $50 shipped
-Tons of AC Lines (Lmk what you need) - OFFER
-OEM Motor Mounts – PM with what you need
-(6) AC Compressor Bracket - $35 shipped
-(3) Coolant Reservoir - $25 shipped
-Power Steering Reservoir - $25 shipped
-(2) OEM Battery Tray (One is missing top bracket) - $30 shipped
-(2) Hood Prop - $20 shipped
(2) Front Windshield Wiper Motors - $30 shipped
-(2) ABS Module - OFFER
-(2) Rotor Shields - $30 shipped
Evo 8/9 Electronics/ECUs/Gauges/OEM Electonics
-AEM Digital Tru-Boost (LIKE NEW) - $220 shipped
-AEM Digital A/F Gauge - $120 shipped
-AEM Digital Fuel Pressure and Oil Pressure (Wired together) - $250 shipped
-AEM V1 ECU Evo 8 - $400 shipped
-Evo 9 ECU - $180 shipped
-E85 Flex Fuel Sensor - $100 shipped
-Steering Wheel Gauge Pod Holder - $30 shipped
-Greddy Boost Gauge - $100 shipped
-Prosport Voltage Gauge -$40 shipped
-Alpine Radio (CDE 110) - $40 shipped
-Evo 8 Wire Harness - $280 shipped
Evo 8/9 Suspension/Brakes/Wheels and Tires/Aftermarket/OEM
-LIKE NEW Volk RE30, 18x9 +35 with Toyo 265/35/18 (Wheels and Tires only have a few hundred miles) - $2500
-RPF1s 17x8.5 +40 with NITTO NT555Rs 245/45/17 Very Nice Condition - $1200
-Brembo Calipers Rear Set - $220 shipped
-OEM Rotors Front and Rear - $80 picked up
-10 ARP Extended Wheel Studs - $20 shipped
-OEM Front Control Arms – $120 shipped each
-OEM Rear Control Arms – PM with what ones you need
-(3 sets) OEM Chassis Braced - OFFER
-(2) OEM Front Strut Bars – OFFER
-(3) Steering Columns with Ignition Switch/Key - $80 shipped each
-Subframe Brace with Front Motor Mount - $100 shipped
-Evo 8/9 Front Subframe - $80 plus shipping
-OEM Mustache Bar - $100 shipped
-4 Rear Spindles (2 with Ebrake and wheel bearing hub) - OFFER
Evo 8/9 Interior/Seats/Consoles/Trim ETC.
-Evo 8 Blue Recaro Front Seat - $200 picked up
-(2) Center Console - $50 shipped
-Shifter Console - $50 shipped
-Evo 9 Climate Control Box - $80 shipped
-Radio/Climate Control Bezel - $30 shipped
-Lower Cubby for MR/RS Gauges - $30 shipped
-(2) Glovebox - $40 shipped
-(3) Gauge Cluster Bezel - $25 shipped
-Evo 8/9 Interior Pieces (I have 3 cars worth or more) - PM what you need
-Dimmer Switch - $15 shipped
-Ashtray - $40 shipped
Evo 8/9 Exterior
-OEM Rear Bumper Tarmac Black - $200
-OEM Rear Bumper Weightless White - $200
-Evo 9 WW GSR Front Lip Great Condition - $100
-Evo 8 Tail Lights (No bulbs or wiring) - $80 shipped
-Tarmac Black Gas Door - $40 shipped
-Evo 9 Driver Headlight, tabs broken, good lense includes ballast - $200 shipped
-Evo 8 RS Driver Headlight for spare parts, pm for info - $100
-Evo 8 HID Ballast - $40 shipped
-(2) OEM Gas Cap - $15 shipped
-Evo 8 Bumper Mesh/Vents – PM what you need
SOLD
-Custom FMIC 4.5” with 3” UICP/Tial Bov - SOLD
-Gruppe S 52mm Gauge Pod - SOLD
-Evo 8 Gauge Cluster with Blue Bezel (93k Miles) - SOLD
-FP Green Journal Bearing MHI Housing Comes with FP Wastegate (Great condition 5k miles) - SOLD
-Precision Turbo 6266 BB with Kit – SOLD
-Shep Trans Ultimate Ratio Trans 5speed - SOLD
-Evo 9 MR 6speed Trans - SOLD
-Aeromotive Fuel Pressure Regulator - SOLD
-BR Ported Throttle Body with Sensors - SOLD
-OMNI 4bar MAP Sensor - SOLD
-Fluidampr Crank Pulley – SOLD
-ARP Headstuds and Main Studs - SOLD
-Tomei Spark Plug Cover - SOLD
-Tomei Heat Shield (Damaged some) - SOLD
-(2) Crank Sensors - SOLD
-Accessory Belt Idler Pulley - SOLD
-OEM Mobil 1 Oil Cap - SOLD
-Power Steering Bracket - SOLD
-AEM Digital Oil Pressure – SOLD
-Brembo Calipers Front – SOLD
-(2) Cusco Front Sway Bar - SOLD
-Cusco Rear Strut Bar - SOLD
-Set of OEM Struts/Tein Lowering Springs - SOLD
-CF (Fake) 3 Pod APillar - SOLD
-Dash Cubby - SOLD
2006 WW IX RS 396/404 - SOLD
Old 11-14-2016   #2
Re: EvoTuna's Newest Partout, FP Turbos, Shep, Trans & Tcases, Frontline Fab, ACT, VO
Is it really that cost prohibitive for you to make a running car out of one of your shells?
Old 11-15-2016   #3
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
List updated and theres only one shell here. I may put it back together but I've done about 3 fix ups this past year and along with parting out another 7-8 crashed ones and working on customer cars its just too time consuming.
Old 11-15-2016   #4
Customer cars!?! You opening a shop or something?
Also, not enough parts. Looks like you have room for more.
Old 11-22-2016   #5
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Lol! I wish I had more room.
I've done some customer stuff, nothing crazy but I am here to help. I've had this shop for almost a year silly
Old 11-22-2016   #6
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Also Black Friday deals posted!
