Old 09-20-2016   #2
Re: Wtb 1g 4g63 or Evo 8 Piston Jets
You're talking oil squirters here right?
Old 09-21-2016   #3
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Same same. Kind of confusing though because the 2g blocks have a little press in squirter I like to call a jet (I've heard them called that elsewhere too). Squirter makes a little more sense for those big ol' goofy things 1gs and Evo.s use.
You might consider just getting new. I know they aren't cheap but at least you know they're decently clean. Should still clean 'em out even when they're new but at least you know there will be no bearing material lodged in them. If you can't find anything and you're in a pinch, try to get a hold of Aric at MAP. He might be able to sell a set.
Good luck.
Old 09-21-2016   #4
Ooh, thanks for the reminder, I have to grab those out of my Evo block to add them to my 2.4 this winter. It's on my project list along with adding balance shafts back in. Sorry.
On second thought, I might have extra 1g ones lying around, I'll check when I get home.
Old 09-21-2016   #5
I should have a set around.
Old 09-21-2016   #6
blackrosenova400
blackrosenova400's Avatar
Thanks guys for checking and letting me know if you have a set! Sorry at work we call them piston jets. I believe its because its what Detroit Diesel calls them.
But yes squirters or piston jets.
While im here if anyone has a 1g clutch setup that is decent that you would like to sell let me know. Not to heavy though, just for a 260-300hp daily driver.
20g Mafia
