Old 07-07-2004   #1
91 GSX- stock fuel pump, 550s, stock FPR.
Sometimes after my car has sat for a while and is completely cold it will not start and the fuel pressure relay and something else near the intake manifold starts clicking rapidly while the key is in the accesory mode after trying to start it.
It acts like it doesnt have fuel. The car stumbles and misses and tries to keep going at around 300 RPM but then dies. I can run the fuel pump through my logger and it runs. I tried checking the fuel pressure relay with the logger but nothing really happens it just clicks a couple times.
After a while of trying to get the car started by raising the idle, stomping on the gas pedal and trying to keeep it going it will pick up and run just fine. This has happened to me about 3-4 times within the last 2 months. I dont know what it could be and I was thinking of getting suggestions before I replace any thing like the TPS or the FP Relay.
-TIA
Peter
Old 07-07-2004   #2
Well I just went out and tried to start it again and it stumbled and did not want to climb past 300RPM. So I followed the clicking and it took me to the fuel pressure selnoid mounted in the firewall. I hav all vacuum eliminations done except the ones to the FP solenoid for cold start reasons... it raises your RPM during startup. I unplugged that and went and tried to start it up.
It started right up and ran perfect. So what could be going wrong with it? With the logger I can test it and it clicks once and shuts off. But when you start it it goes nuts. Well it was an easy fix but I dont get how that could make the car run so shitty. Anyone know why that solenoid produce the results it did?
Old 07-07-2004   #3
Enes
Enes's Avatar
maybe its the loose screw between the stearing wheel and the seat?
-E
Old 07-07-2004   #4
That could be but that has no explanation either than... Im stuck. :cry:
Old 07-07-2004   #5
Well the problem is back after it ran fine for a little bit idling.. I took it down the block and it started dying and bucking under load. made it back home though after a few attempts.
Im thinking its the ISC motor but Im not sure. The FP solenoid is eliminated and that lowered my idle a little, not sure why...
Any theories??
Old 07-07-2004   #6
Jana
Mazda Bitch
Kind of sounds like the problem my eclipse had when I bought it. It threw and ISC code, but I never replaced it because some days it started fine. Then one day, it just went away and hasn't done it for over a year. Strange...
Old 07-07-2004   #7
1Fst14B
Send a message via AIM to 1Fst14B
does the FP relay click and click AND "something near the intake manifold" click at the same time, or are you assuming that only the FP relay is clicking?
the ISC can make a rapid clickign sound at various times when the ign. is on.
but the FP relay shouldnt and if it does
CAPS!!
Adam
1Fst14B is offline   Reply With Quote
Old 07-07-2004   #8
1Fst14B
also the fp solenoid usually is only used for hot starts...it doesnt seem to be used for cold starts...
and it shouldnt make your idle any different...it just modifies fuel pressure
Adam
Old 07-07-2004   #9
Originally posted by 1Fst14B+Jul 7 2004, 06:16 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (1Fst14B @ Jul 7 2004, 06:16 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-EclipseTurbo@Jul 7 2004, 01:11 PM
CAPS!!
Adam [/b][/quote]
The intake manifold clicking is coming from the ISC, and the other clicking was coming from the fuel pump relay in the dash and also the fuel pressure solenoid on the firewall.
I checked my caps 2 years ago and they looked fine, I even bought the replacement ones and I think I lost them becuase nothing seemed to leak.
Does this sound like the ECU is going to crap? If I take out the ecu and there is nothing leaking or any corrosion what should I do?
Old 07-07-2004   #10
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Find Eric and have him do the caps, or get them from him and do them youself if you are up to it. Just cause you can't see any damage yet doesn't mean it's not in progress.
Old 07-07-2004   #11
joem
Drives: 1991 Talon awd auto
Boost leaks?
joe
Old 07-07-2004   #12
No these are not symptoms of boost leaks... Its very random so Ill replace the CAPS and see what happens.
Old 07-08-2004   #13
Does the car start fine after its warmed up. If it does I would check your coolant temp sensors. If one of them is defective it will send the cars ECU into a limp mode and the car will think the air temp outside is really hot, therefor not sending enough fuel to start the car properly. If none of that applies then nevermind.
CRAIG
Old 07-08-2004   #14
Well after driving to normandale this morning for class I discovered that I wasnt going to get lucky and the car wouldnt start to take me home... So after a gay day I took my ECU to Eric- LightningGSX and he opened it up and yea the caps leaks all over. Pretty bad too. Well see if he can repair it or not. I put a spare one in my car with replaced caps for now and drove it home just fine!
If mine is shot Eprom anyone?
Old 07-08-2004   #15
those caps are sneaky bastards
Old 07-09-2004   #16
john
Business as usual
john's Avatar
You are on the stock fuel pump? I thought you and CVD swapped in a 190.
97 Viper GTS
Old 07-09-2004   #17
No I had some problems with it starting becuase I ruined a bolt that connects the ground from the pump to the actual tank so I took it out and got a new sending unit and put the stocker back in becuase I needed to drive it... never got around to putting it back in.
