Old 08-11-2004   #1
JustROLLIN
SpunBearing
JustROLLIN's Avatar
I have looked at several different sources showing that I can remove ALL the solenoids on the firewall. But, I have also seen a couple showing that I need to keep the solenoid on the left. (Facing the engine) The solenoid that has some sort of electrical wire running along the firewall. I havent traced it so I dont know where it goes. Opinions? Experience?
Old 08-12-2004   #2
Khadgar
Can't Actually Wrench
Send a message via AIM to Khadgar
http://www.taboospeedshop.com/emissions.htm
That help?
Khadgar is offline   Reply With Quote
Old 08-12-2004   #3
Taboo's diagram pretty much explains it all.
Old 08-12-2004   #4
john
Business as usual
john's Avatar
Appartently I am running the "race only" setup.
97 Viper GTS
Old 08-12-2004   #5
If you are talking about removing the FPR solenoid I did that on my car and had no cold-starting problems; you probably only would with a stock pump. It was amazing how clean and empty my engine bay was with all the emissions systems and solenoids removed, I loved it.
Old 08-12-2004   #6
JustROLLIN
SpunBearing
JustROLLIN's Avatar
So people are keeping the FPS? Would the "race only" setup be ok for a car that is strictly summer driven?
Old 08-12-2004   #7
JustROLLIN
SpunBearing
JustROLLIN's Avatar
Thats all I needed to know. Thanks Chris. I will run the "race only" setup. Thanks for the help guys!
Old 08-12-2004   #8
The FPR solenoid is actually for hot starts... it raises you fuel pressure to prevent gas starvation to the engine. I ran without it for a while and it seemed ok but starting took a little more juice.
Old 08-14-2004   #9
john
Business as usual
john's Avatar
The "race only" setup is in my dsms without any problems.
97 Viper GTS
Old 08-14-2004   #10
Joe, ask to see under my hood the next time you're at QPR... You'll be amazed at how clean it is.
Old 08-14-2004   #11
JustROLLIN
SpunBearing
JustROLLIN's Avatar
Cool, I'll do that. I am going to use the race only setup since most are running it without issues.
