Old 11-14-2003   #1
jpretz
Send a message via AIM to jpretz
Half of my key broke off in my ignition today. Cheap ass thing. I can still start it but i only have a half of a key. Anyone know of a way to get it out or anything?
Thanks,
Jayme
:fworld: :fworld: :fworld: :fworld:
jpretz is offline   Reply With Quote
Old 11-14-2003   #2
Enes
Enes's Avatar
you best bet is to put a tiny drop of super glue on the key side that you have..
and stick it in there... hold it there a bit and hope it wasnt too big of a drop ...
and then try pulling it out slowly..
Old 11-14-2003   #3
Hey perfect time for winter, now you might as well just go by a remote start with keyless entry. Then there is no need for a key. WOOT...
It will be a son of a bitch getting that key out with out taking the ignition out. And you don't want to mess with that much cause you can screw up the tumblers and then the ignition is fucked.
Old 11-15-2003   #4
john
Business as usual
john's Avatar
Drive it to a locksmith and they can take it out. I have done it before on house locks. All you need is the right pick. Then it isn't too hard. (I work at a hardware store that does locksmithing)
97 Viper GTS
Old 11-15-2003   #5
jpretz
What is that gonna run me?
Old 11-15-2003   #6
john
Business as usual
john's Avatar
I did it for someone on a deadbolt. I only charged them $2 because I didn't know how much it was supposed to cost and it took me 2 min. I am not sure about a car lock though. Where are you located? Try calling Hance Ace Hardware on monday around 5 or so and ask for Jeff. He will give you a price quote.
97 Viper GTS
Old 11-15-2003   #7
jpretz
I live in Apple Valley.
Old 11-16-2003   #8
john
Business as usual
john's Avatar
Just look up a local locksmith then. It shouldn't cost much more than $20 if you bring the car to them and they get it out in a reasonable amount of time. I will ask him when I see him though. See what he would've charged. That will give you some idea how much $.
97 Viper GTS
Old 11-16-2003   #9
jpretz
Thanks!
Old 11-16-2003   #10
jpretz
The locksmith i called wanted anywhere from $75- 300!!! Does anyone know anybody who could do it for me?
Old 11-16-2003   #11
Enes
Enes's Avatar
Like i mentioned...
I did it on my car before.. i put a small drop very small.. on the end of the key and then put it in, that will fuse the two parts together and then pull it out..
also jb weld would work as well, just a small dot..
-Enes
Old 11-16-2003   #12
jpretz
And what happens if it gets stuck?
How long do i leave it on for?
Old 11-16-2003   #13
Enes
Enes's Avatar
use just a small dot of it, and put it on the side of the key.. and push it in and leave it about 5 seconds and pull it slowly back out... it worked on my oldsmobile 7 years ago .... but i've never taken the keylocks on DSMs there should be something to push against so that it sticks
-E
Old 11-16-2003   #14
jpretz
Why would i put it on the side of the key???
Old 11-16-2003   #15
Enes
Enes's Avatar
ok.....
lets see...
use logic.. put glue where two peaces would come together...
broken peace
BBBB
your key part
===KKKKK
Now put glue between B and =
get it?
-E
Old 11-16-2003   #16
john
Business as usual
john's Avatar
You would put the glue on the tip of the key then (where it probly broke). Call other losksmiths. I wouldn't use the glue idea myself. What if it gets stuck? Then you will be paying mitsu a lot for a new lock. I will call our locksmith and see what he charges as I have tomorrow off.
97 Viper GTS
Old 11-16-2003   #17
jpretz
OK thanks! Where are you located? :3gears:
Old 11-16-2003   #18
john
Business as usual
john's Avatar
I am in Hopkins. About 30min from Apple Valley. He is alos a mobile locksmith meaning that he would go out and do it for you also. It would be much cheaper to drive to him though. I will get quotes tomorrow for if you come here and if he goes there.
97 Viper GTS
Old 11-16-2003   #19
Iceman
Jpretz I know you can do it. Even if you are a girl i still think you can handle it... You should be okay though... if you really really really need help ill get john to go up there and help you :P. Or me i guess eh whatever.
Old 11-16-2003   #20
jpretz
:toast: Well some guy is coming out here tom. to look into buying it. Hopefully he will. But still please post up quotes! I appreciate it!
