Old 01-06-2005   #1
TGPilot
TGPilot's Avatar
Replace 2 or all 4 tires at once?
So with a 1994 AWD Talon, or any other year AWD for that matter, do you have to replace all 4 tires at the same time? I ask this because I only need to replace 2 tires due to excessive camber wear on the passengers side. The other two tires are in pretty good to excellent shape.
My concern would be the difference in circumference of the tires and having different rotating speeds between front and rear axles.
Thanks, and that will be the last of my idiot questions for a little while!
Old 01-06-2005   #2
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: Replace 2 or all 4 tires at once?
How worn are the other two tires? If they are way off you can burn shit out.
If it was my car I would do all four.
Old 01-06-2005   #3
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Do all 4...sell the two that are ok, to FWD guy like me so I can burn them up.
Take her to the limit!
Old 01-07-2005   #4
TGPilot
TGPilot's Avatar
Sounds like a good idea. I am going to get all 4 done this weekend along with an alignment...
Old 01-07-2005   #5
Moved to correct area.
CRAIG
Old 01-07-2005   #6
TGPilot
TGPilot's Avatar
CRAIG
oops sorry CRAIG! I looked around on the Thread mains and for some dopey reason I didn't see "Wheel/Tire Tech". I will look better next time!
Old 01-07-2005   #7
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
If you are buying the same kind of tires I wouldnt worry about it.
I've run my car with low tires for weeks upon weeks at a time. My trans never blew up. The cars are designed to have some slip in the drivetrain to allow for things like this.
Old 01-29-2005   #8
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
same here, i've ran different tires on my car before. as long as they are in the same specs you shouldn't have a prob
