Old 02-21-2005   #1
chengsta
chengsta's Avatar
Drives: '93 mirage es - evoIII
SSQV BOV help
I installed a SSQV BOV w/ recirculation kit in my 1990 eagle talon tsi 5spd and took it for a drive but for some reason at full boost it would spike at 15psi then drop right back down to 10psi (I have my MBC set to 15psi). Anyone have an idea of why it does that? I think it has something to do with the SSQV but not sure.
chengsta is offline   Reply With Quote
Old 02-21-2005   #2
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
Re: SSQV BOV help
Is your boost controller hooked up properly?
Old 02-21-2005   #3
chengsta
chengsta's Avatar
Re: SSQV BOV help
Yes I have my MBC installed correct. I ran 15psi with my 1g BOV just fine.
Old 02-21-2005   #4
Re: SSQV BOV help
It is probably the vacuum line to the BOV. Make sure that is hooked up correctly. I am willing to be that you did not zip-tie the connections of the hose. They are probably blowing open, which will release the BOV and you lose your boost.
Old 02-21-2005   #5
dsm95gsxer
dsm95gsxer's Avatar
Re: SSQV BOV help
If it is similar to other aftermarket bovs you should be able to adjust how responsive the bov will be, wether it be by adding washers or turning an adjustment screw.
dsm95gsxer is offline   Reply With Quote
Old 02-21-2005   #6
SuperSleeper
Re: SSQV BOV help
Yes, the SSQV has an adjustment bolt... impossible to miss.
Old 02-21-2005   #7
chengsta
chengsta's Avatar
Re: SSQV BOV help
Re-checking my vacuum line(s) for leaks might be a good idea. From what I read about the adjusting screw on the SSQV, all it does is adjusts the sound but don't quote me on that. That's justs what I found out on it.
Old 02-21-2005   #8
Re: SSQV BOV help
Yep, don't listen to them. The HKS is of a different design than most BOV's. Don't mess with the screw.
Old 02-21-2005   #9
chengsta
chengsta's Avatar
Re: SSQV BOV help
Just checked my lines while at idle and no vacuum leak seem to be present. I would free rev the car and see if any air leaks at higher rpms but can't do that or else my neighbors gonna call the cops on me hehehe. Sucks living in a neighborhood sometimes :P.
Old 02-21-2005   #10
Re: SSQV BOV help
You won't have a vacuum leak, just boost leaks. Trust me, if those lines aren't zip-tied, they will leak. I have an HKS also and we forgot to put one on once, it does exactly what you are talking about.
Old 02-21-2005   #11
chengsta
chengsta's Avatar
Re: SSQV BOV help
Oh really? Looks like I'd have to go back and zip-tie them all tighter and see if that solves my problem. Thanks for the info.
Old 03-02-2005   #12
Re: SSQV BOV help
Why is it soo important to re-circulate the air? I guess the biggest downfall to it, for me, is that I don't get to hear the bov..
-A. Swift
Old 03-02-2005   #13
Re: SSQV BOV help
-A. Swift
http://www.dsmtuners.com/forums/showthread.php?t=113858
...and by the way, since you haven't formally introduced yourself in the Members Intro's forum, welcome to DSMStyle!
Old 03-02-2005   #14
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Re: SSQV BOV help
That and the poor idle combined with the tendency to stall out between shifts. To recirculate or not is the famous first Tooners question. General rule of thumb, don't vent unless you have a GM MAF in blow-through, or an AEM.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 03-02-2005   #15
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Re: SSQV BOV help
Damn you Jakey, I should've known not to challenege the internet link master...
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 03-03-2005   #16
Re: SSQV BOV help
oh..i should go do that..thanks..
-A. Swift
Old 03-03-2005   #17
Re: SSQV BOV help
I think its just an hks thing. Mine does the same thing, spikes up to 20 psi then drops to 15. Sometimes when im like 3/4 throttle it will stick at 20, but if i go full throttle it will usually drop to 15 psi. Its done that since i got it.
Old 03-03-2005   #18
Re: SSQV BOV help
Did you guys put the little filter in line? Mine works perfectly.
Old 03-04-2005   #19
Re: SSQV BOV help
why are you switching the bov's anyway? I mean..doesn't your 1st gen still work? Or, can we actually hear the bov sound with these ones? See, I always thought that if you recirculated, you cannot hear it..
-A. Swift
Old 03-04-2005   #20
Re: SSQV BOV help
you can hear my recirculated bov just fine. Soon as you get rid of your air filter box, it'll become much louder. And the 1g will only hold so much boost. I too plan on getting an HKS one of these days.
